92-93ish Pajero fuel economy 2.5L TD and 2.8L TD
#902075
08/25/08 04:31 AM
Could owners of these post their average fuel economies? I am trying to decide which SUV of this era to buy.
Thanks!
Re: 92-93ish Pajero fuel economy 2.5L TD and 2.8L TD
[Re: Brad]
#902076
08/25/08 10:47 AM
im getting 25mpg with my 89 specs are listed in sig box
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED 1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW CURRENTLY LOCATED IN JAPAN
[Re: Brad]
#902077
08/25/08 02:01 PM
varies between 9.0 and 10.5 l/100km (27 to 30 mpg, imperial gallons that is), depending on whether I drive at 85-90 kph or 95-100 kph, proportion in town, etc. . 91 SWB 2.5TDI
[Re: tengopajero]
#902078
08/27/08 06:58 AM
The best I got in city 9,6 L/100 km. More often 9,9-10,6. Depends on tire pressure and you driving style.
Fight for Right to drive from Right! www.ivoac.caStay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
[Re: Pajerist]
#902079
08/27/08 07:15 PM
I get about 750Km on 80L-83L (city or highway it doesn't change). If you could drive at 80 km/h you would get even better. These vehicles get great fuel milage in town, but because of the low gearing 2700 RPM doing 100KM/H the #'s don't change for the highway. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1991 MITSUBISHI PAJERO EXCEED
[Re: DonM]
#902080
08/27/08 07:44 PM
i get 20mpg city or highway...doesn't matter. i run 33's. Fresh K&N. How can i get the higher #'s you guys get? one tank=550-600kms <img src="/forums/images/graemlins/zombie.gif" alt="" />
Get on the 'RIGHT' side of Health.
[Re: Spinalguy]
#902081
08/27/08 09:25 PM
US gallons? Full size pajero?
Mine's a SWB -less weight. I get 100km/h at 2500 RPM so running at 90 KM/h is only about 2250 RPM.
[Re: tengopajero]
#902082
08/28/08 12:41 AM
Full size and US gallons. 4.88 gears
[Re: Spinalguy]
#902083
08/28/08 03:02 AM
Do you have the 93L tank? If you do you are getting really crappy milage. I would try and keep the right foot up a little more or if that isn't the problem get the injectors cleaned.
[Re: Spinalguy]
#902084
08/28/08 04:23 AM
i get 20mpg city or highway...doesn't matter. i run 33's. Fresh K&N. How can i get the higher #'s you guys get? one tank=550-600kms <img src="/forums/images/graemlins/zombie.gif" alt="" /> How may liters are you burning to go 550 kms? Give us numbers in liters per 100 kms and we then have an accurate measure to compare it with.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6373 MB (Peak: 0.7437 MB) Data Comp: Off Server Time: 2026-06-22 11:19:28 UTCValid HTML 5 and Valid CSS
