94 4wd toyota leaking clear fluid????? #902276 08/26/08 04:55 AM
I
islandpsd Offline OP
i noticed a leak under my truck and i dont know what its from. its clear with the viscosity of oil and after i shut the engine off, it leaks for about 15 min then it stops. can anyone help???
1985 Toyota 4x4 22R straight axle, Stock height, Original owner
Re: 94 4wd toyota leaking clear fluid????? [Re: islandpsd] #902277 08/26/08 04:59 AM
4Crawler Offline
Where under the truck is the leak showing? Do you have A/C? Might be the A/C drain that comes down at the passenger front side, behind the tire.
Re: 94 4wd toyota leaking clear fluid????? [Re: 4Crawler] #902278 08/26/08 06:08 AM
Adam F Offline
I agree, its the A/C drain. Does it dry up an not leave a stain? If so, its just the water from the A/C. Perfectly normal. Every vehicle with A/C does it.
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5942 MB (Peak: 0.6474 MB) Data Comp: Off Server Time: 2026-06-07 05:52:58 UTC
