steering column/gearbox #902304 08/26/08 04:03 PM
spanky Offline OP
Can someone tell me if there are other makes of parts that will replace the steering column and/or the steering box in a 1989 Jeep YJ with automatic trans and power steering?
89 YJ
Re: steering column/gearbox [Re: spanky] #902305 08/26/08 05:34 PM
jstritec Offline
I would do a google search and you will find all kinds of stuff.
80 CJ-7.
It runs
Re: steering column/gearbox [Re: spanky] #902306 08/26/08 05:52 PM
spanky Offline OP
I did that couldn't find much . That's why I turned to this forum
89 YJ
Re: steering column/gearbox [Re: spanky] #902307 08/28/08 03:05 AM
Berkeley Offline
Jeep Moderator
My '90 XJ steering column is a GM tilt, same as millions others. Maybe yours is the same.
Cherokee XJ Steering Wheel Repair
Re: steering column/gearbox [Re: Berkeley] #902308 08/31/08 02:38 PM
spanky Offline OP
Thanks for the suggestion but from what I can tell the YJ is different if anyone knows for sure please comment.
89 YJ
Re: steering column/gearbox [Re: spanky] #902309 09/04/08 02:13 AM
hlhneast Offline
As afar as I can tell, the non tilt column for CJ & YJ are Jeep products and the parts are not interchangable with the GM style tilt columns. Now that being said, any column that is close in length and has the same diameter and splines should interchange with some mods. Since the tilt is a GM product, those columns should be good candidates and I would look there first. Since there is a rod between the column and the steering box, lots of mods could be done here to convert what you want. As far as the steering box itself, I dont know of any other bolt up options but if you dont mind putting more holes in the frame, same idea goes. You can modify anything to work, its just the amount of effort involved to get what you want. Depending on what your goals are, there are alot of bolt on aftermarket products to beef up the steering. If you are looking for parts for your stock stuff, 4wd.com is a good source but you're probly gonna have to make a trip to the junk yard. I just bought a whole tilt column out of a Waggoneer for $75 for the parts I need. I am going to check the length and other measurements just for general knowledge and I will post the results if you need them. <img src="/forums/images/graemlins/notooth.gif" alt="" />
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
Re: steering column/gearbox [Re: Berkeley] #902310 09/04/08 02:29 AM
hlhneast Offline
Hey Berk, where did ya get the nifty red handle tool to remove the spring clip on the column and what is it called? Thanks! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: steering column/gearbox [Re: hlhneast] #902311 09/13/08 06:12 PM
Brown81CJ5 Offline
It can be found at any parts store. It is a lock plate compressor.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6229 MB (Peak: 0.7011 MB) Data Comp: Off Server Time: 2026-06-22 23:05:46 UTC
