1st Gen SR5 Seats #902321 08/26/08 07:13 PM
Z
Zolton Offline OP
I recently acquired a set of seats from a 1985 4runner and have installed them in an 89 4runner. I've noticed that the passenger side does not adjust back as far as the driver's side making it uncomfortable for anyone over 5"5 to ride shotgun. Is there any way to remedy this? thanks
Re: 1st Gen SR5 Seats [Re: Zolton] #902322 08/27/08 03:21 AM
Richards19884x4 Offline
(You knew this was coming, right?) Do NOT, under any circumstances, allow anyone OVER 5'5" to ride shotgun, or they will be uncomfortable. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Seriously, I sat here for nearly a minute trying to resist writing that, but no luck. I promise, in the future, to try really hard to refrain from doing certain things.
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: 1st Gen SR5 Seats [Re: Zolton] #902323 08/27/08 09:16 AM
toyrunner Offline
I do believe the seat rails are different from 85 to the 89.
They slide differently <img src="/forums/images/graemlins/baby.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: 1st Gen SR5 Seats [Re: toyrunner] #902324 08/27/08 04:56 PM
bkg Offline
Seat rails are the same. I've never seen a difference. I suspect something wrong with the locking mechanism. It's really not that hard to swap rails, if you need to do so. Done it a few times for 4Runner to Truck installs.
Brian K. Gallus
Re: 1st Gen SR5 Seats [Re: Zolton] #902325 08/28/08 10:33 AM
DRTDEVL Offline
Sounds like it is stuck forward.
When you flip the seat forward, does it slide the bottom about a foot closer to the dash? If not, slam it upright hard while pushing the whole thing to the rear.
My seat would stick from time to time in the forward position... Until I put MR2 seats in to replace them.
Re: 1st Gen SR5 Seats [Re: DRTDEVL] #902326 09/03/08 04:04 AM
G
Greg_Canada Offline
The seats in my 89 do the exact same thing. the driver side goes back farther than the passenger side by about an inch. (if it's more than an inch, there is something wrong).
BTW i'm 6'4 and so is my bud, and he sits there (and doesnt complain, i know it's not huge tho)....
89 4Runner
Re: 1st Gen SR5 Seats [Re: Greg_Canada] #902327 09/13/08 01:49 PM
MisterZee Offline
What he said...
The pass seat is a one- P.O.S.ition setup... its either back in sitting position... or forward to let passengers from the rear in/out. Always remember to slide the seat back till it stops before tilting the seat-back into position... I have replaced the cables in that seat before once or twice... and doing that will improve longevity... sorry for TMI ...
98 Taco 4WD
Re: 1st Gen SR5 Seats [Re: Zolton] #902328 09/16/08 07:34 PM
Q
qdude79 Offline
When you originally installed the seats, did you check to see that each rail was in a similar position (ie: both all the way forward or all the way back)? I've pulled seats before by grabbing the adjustment handle, only to have one of the rails slide to a different position without me knowing it. When I go to reinstall the seat, the rails are offset, causing the whole setup to bind and not want to move all the way forward or backward.
Remedy: pull the seat, pull up on adjustment lever, manually slide both rails FORWARD. This positions them all the way under the seat bottom and is easier to wiggle the seat through the doorway. Loosely mount your four bolts and try moving the seat all the way forward then back a few times.
Hope this works for you.
Qdude
"The only true wisdom consists in knowing that you know nothing."
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.015s) Memory: 0.6242 MB (Peak: 0.7226 MB) Data Comp: Off Server Time: 2026-11-04 20:02:20 UTC
