valve's man, valves #902995 08/29/08 08:58 PM
Knucklepin Offline OP
I've decided to go with a 261c cam and engine kit for my 22r. My question is this: Are there any special tricks or tolerances to be followed when adjusting the valves on this cam or do I just follow my repair manual instructions? <img src="/forums/images/graemlins/confused.gif" alt="" />
If a man throws a wrench and no one is there to see it; does it still count as pitching a fit?
Re: valve's man, valves [Re: Knucklepin] #902996 08/29/08 09:06 PM
Staceman Offline
EB will give you the values when they ship the cam. Should be marked on the box. Mine is 6 and 9 thou. Stock is 8 and 12.
Re: valve's man, valves [Re: Knucklepin] #902997 08/29/08 10:27 PM
engnbldr Offline
>>>*All three designs we have are now tight lash lobes, set them at .007" intake and .009" exhaust.
Ted
*Beats the he** outa me!....*LOL**...
Re: valve's man, valves [Re: Knucklepin] #902998 08/30/08 02:11 AM
kewlynx Offline
Might give this a little read too.
http://www.4x4wire.com/toyota/tech/cam_degreeing/
**ubi apis- ibi salus**
Re: valve's man, valves [Re: kewlynx] #902999 08/30/08 04:06 AM
Thank you for that Kewlynx. That was good information and a really simple cut and dried explanation. Now, all that being said; will the cam and timing set that comes with my kit be fully adjustable? I'm used to a chevy, which have all the adjustment on the crank gear, line up the dots and away you go (barring any serious material removal from the deck or head.) If it isn't fully adjustable; then how likely am I to have to adjust the cam one full tooth one way or the other? Or am I just not getting it? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: valve's man, valves [Re: Knucklepin] #903000 08/30/08 06:00 AM
engnbldr Offline
>>>*One full tooth would be a LONG ways! That isn't likely to ever be required.
On a few engines that have had a lot of head/block material removed we find a degree or two can make quite a difference.
On most of the 22R/RE engines it is bolt it up and go....*EB
Re: valve's man, valves [Re: engnbldr] #903001 08/30/08 07:10 AM
Thank you again. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6181 MB (Peak: 0.6922 MB) Data Comp: Off Server Time: 2026-11-02 14:18:05 UTC
