87 4runner replacing idler arm bushings
#903161
08/30/08 11:24 PM
Can the idler arm bushings be replaced on the vehicle or do I need to take the unit off? Is a press needed to replace/install these bushings?
Re: 87 4runner replacing idler arm bushings
[Re: hazman]
#903162
08/31/08 12:00 AM
[Re: philly]
#903163
08/31/08 12:22 AM
Thanks Philly! Exactly what I needed to know.
[Re: hazman]
#903164
09/02/08 02:37 AM
you do not have to pull the joint (idler arm stud to steering link) apart. you can take the body off the shaft. leave the shaft attached to the steering link... less work and potentially ruining the rubber.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6001 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-06-20 18:15:11 UTCValid HTML 5 and Valid CSS
