Greasing speedo cable #903275 08/31/08 03:48 AM
BobRowe Offline OP
I need to grease the speedometer cable on my CJ7. It's not very old (less than 200 miles), but I forgot to grease it when I recently replaced it. I don't want to buy another batch of grease. I have the following greases available in my garage:
1. Chassis grease
2. Wheel bearing grease
3. Lubri-Plate (white lithium grease)
4. Dielectric grease
5. Vasoline patroleum jelly
Which would you use?
Re: Greasing speedo cable [Re: BobRowe] #903276 09/02/08 04:38 PM
BigJim Offline
Bob it prolly has all the grease in it that will be needed but If you just MUST take it apart I'd be for looking at what is in there already and copying it..
Re: Greasing speedo cable [Re: BobRowe] #903277 09/02/08 08:09 PM
DBL_DTY97TJ Offline
I've used bearing grease on all sorts of cables and never heard another peep outta them. I'm sure white lithium would do fine too.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Greasing speedo cable [Re: DBL_DTY97TJ] #903278 09/03/08 01:44 AM
Mike Bondi Offline
White lithium grease should not be used on speedo cables, because it will attack the fabric core of the cable. Heavy wheel bearing grease might cause problems, if you live where it get's c...ccc..cold......Vasoline should work fine <img src="/forums/images/graemlins/scared.gif" alt="" />.....be cool...Mike <img src="/forums/images/graemlins/oink.gif" alt="" />
2013 Wrangler Rubicon, 2014 Jeep Cherokee Latitude, 09 Mercedes Benz ML350 4matic...Old scooter trash trying to do good, in the flat lands of Indiana
Re: Greasing speedo cable [Re: Mike Bondi] #903279 09/03/08 02:31 AM
BobRowe Offline OP
Thanks for the suggestions, guys.
BTW, it didn' have lube on the inner cable when I got it. I made a mental note to grease it before I installed it, but then somebody stole the note!
Re: Greasing speedo cable [Re: Mike Bondi] #903280 09/03/08 01:56 PM
DBL_DTY97TJ Offline
oop. My bad.
Re: Greasing speedo cable [Re: BobRowe] #903281 09/03/08 03:45 PM
BigJim Offline
Yup! That'l happen! And by the time you are 70 or so you won't even remember to type it in here.. Ask someone that knows..
Re: Greasing speedo cable [Re: BigJim] #903282 09/04/08 09:17 PM
BobRowe Offline OP
Horrors!!!! I only have about 2-1/2 years to go... and already I have repeated esipodes of CRS syndrome! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Greasing speedo cable [Re: BobRowe] #903283 09/15/08 10:14 AM
superdawg Offline
Mike Bondi, back at it, how the heck are you?
SD
Re: Greasing speedo cable [Re: superdawg] #903284 09/16/08 04:38 AM
Mike Bondi Offline
Life is Good!! You know I have a difficulty in staying quiet....Be cool..Mike <img src="/forums/images/graemlins/oink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6310 MB (Peak: 0.7387 MB) Data Comp: Off Server Time: 2026-07-14 12:37:11 UTC
