replace pitman arm? #903289 08/31/08 05:14 AM
bloodbath4runner Offline OP
Just replaced both driver side tie rod ends, but the pitman arm isn't looking that good... I think. thoughts?
Click the pic for higher res
You know you're in for a rough night at sea when the barometer does this:
Re: replace pitman arm? [Re: bloodbath4runner] #903290 09/01/08 09:52 PM
Snowtoy Offline
It is hard to tell from the pic, other than the rust and what looks like a torn grease boot. Is there any play in it, or with the wheels on and the front off the ground can you move the tires in and out w/o moving the idler arm or the rest of the steering linkage, except for the pitman?
Re: replace pitman arm? [Re: Snowtoy] #903291 09/02/08 06:00 PM
tires don't move when I get them off the ground - just that boot is torn. I am a trained monkey that needs to ask before attempting anything new.
Re: replace pitman arm? [Re: bloodbath4runner] #903292 09/03/08 12:50 AM
Snowtoy Offline
If there is a zirk fitting or bolt(where a zirk fitting would go), you could hit it with some grease, and change it out later. It is basically up to you and what you want to do.
W/o the boot the joint is exposed to the elements which will cause it to wear out sooner, but with everything still tight, it isn't something that has to be done right now.
Re: replace pitman arm? [Re: bloodbath4runner] #903293 09/03/08 03:38 AM
RatLabGuy Offline
You still in school at Dooooook?
That 'splains it, lol.
Like above, I'd grease it and let it wait until money and time aren't so tight, and you have another reason to be messing in there anyway.
Maybe could have justified it when you took off teh tie rod, but prob not now.
And don't forget - you prob need an alignment now.
Question Reality.
Re: replace pitman arm? [Re: RatLabGuy] #903294 09/04/08 03:03 AM
yup still at duke but not for long! So no money and no time - must fix what must absolutely be fixed so I don't die (like an inner tie rod end that was about to fall apart <img src="/forums/images/graemlins/lol.gif" alt="" />)
And I did actually dig deep and shell out the $ for an alignment - the most expensive part <img src="/forums/images/graemlins/frown.gif" alt="" />
need to get back to saving the world <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PS - even a trained money like me can tell the difference between Wallace Wade and what is it called... kenan memorial stadium
Re: replace pitman arm? [Re: bloodbath4runner] #903295 09/04/08 05:47 AM
Adam F Offline
If your worried about it, you can get a new boot cheap.
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6168 MB (Peak: 0.7085 MB) Data Comp: Off Server Time: 2026-07-13 05:34:23 UTC
