Page 3 of 3 1 2 3
Re: Grand Cherokee Fishtail problem [Re: trex117] #904047 09/14/08 02:00 AM
trex117 Offline OP
I'm back ..but no news. I'm going to make a list of what everyone suggested and give it to her and tell her to give that to the dealer and say "fix it!" I'll still post new info when I get it. I think the tires are stock, I asked her how she puts it in 4WD and she showed me a button on the dash. I dont know - I have a 92 wrangler..mine has a stick to put in in 4WD.
Okay going by the thread
1) limited slip differential broken
2)speed sensor
3) differential gear additive
4)esp system
did I miss anything?
Re: Grand Cherokee Fishtail problem [Re: trex117] #904048 09/14/08 02:04 AM
trex117 Offline OP
I guess I'll mention a speed sensor switch then? I wish I new a competent mechanic here. thanks. any other info is appreciated .
HOLY CR*P!!!!!!! No wonder reepersteve felt like he wore out his welcome!! I meant " I wish I new a competent mechanic hereWHERE I LIVE -not on this forum.
sorry. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Grand Cherokee Fishtail problem [Re: trex117] #904049 09/14/08 03:49 AM
BigJim Offline
I, for one, knew zackly what you meant.. But then I don't wear my FEELINGS on my sleeve.. He'll be happier somewhere where carb spacers rule anyway.
Re: Grand Cherokee Fishtail problem [Re: trex117] #904050 09/14/08 06:15 AM
cuervo25 Offline
Well if you felt like bringing it to northern jersey I know of a few really good techs.
Re: Grand Cherokee Fishtail problem [Re: cuervo25] #904051 09/21/08 08:55 PM
CoachJames Offline
I upgraded my zj limited to bigger gears(front and back) and added limited slip to front end.
Mechanic did great job but didn't put abrasive additive into front diff and it pulled left and right.
Once we added it worked great!
PS: Most garages, JLube & EZ don't know about required additive and dont put it in. Most likely a mechanic drained and refilled diff without additive in back diff. Get kit which is like radiator test tube and test additive level or presume it contains none and ADD some until corrected...
Coach James
Re: Grand Cherokee Fishtail problem [Re: BigJim] #904052 09/21/08 09:35 PM
80CJ Offline
I have a question to insert here... Does the female even KNOW what a fishtail is? Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Hell Jim, I should hope so. Some women HAVE fishtails. Here's picture proof... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Grand Cherokee Fishtail problem [Re: 80CJ] #904053 09/27/08 06:58 PM
trex117 Offline OP
I caught her once and threw her back. Too much bitc*in'. You had to see me get the hook out of her mouth! <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Grand Cherokee Fishtail problem [Re: CoachJames] #904054 09/27/08 07:00 PM
trex117 Offline OP
I had my wrangler diff lube changed at a 10 minute oil place against my better judgement. they talked me into it. Thats when my diff started leaking and making noises. never again.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6310 MB (Peak: 0.7462 MB) Data Comp: Off Server Time: 2026-06-10 07:23:39 UTC
