Re: Grand Cherokee Fishtail problem
[Re: trex117]
#904047
09/14/08 02:00 AM
I'm back ..but no news. I'm going to make a list of what everyone suggested and give it to her and tell her to give that to the dealer and say "fix it!" I'll still post new info when I get it. I think the tires are stock, I asked her how she puts it in 4WD and she showed me a button on the dash. I dont know - I have a 92 wrangler..mine has a stick to put in in 4WD. Okay going by the thread 1) limited slip differential broken 2)speed sensor 3) differential gear additive 4)esp system did I miss anything?
[Re: trex117]
#904048
09/14/08 02:04 AM
I guess I'll mention a speed sensor switch then? I wish I new a competent mechanic here. thanks. any other info is appreciated . HOLY CR*P!!!!!!! No wonder reepersteve felt like he wore out his welcome!! I meant " I wish I new a competent mechanic hereWHERE I LIVE -not on this forum. sorry. <img src="/forums/images/graemlins/scared.gif" alt="" />
[Re: trex117]
#904049
09/14/08 03:49 AM
I, for one, knew zackly what you meant.. But then I don't wear my FEELINGS on my sleeve.. He'll be happier somewhere where carb spacers rule anyway. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: trex117]
#904050
09/14/08 06:15 AM
I guess I'll mention a speed sensor switch then? I wish I new a competent mechanic here. thanks. any other info is appreciated . HOLY CR*P!!!!!!! No wonder reepersteve felt like he wore out his welcome!! I meant " I wish I new a competent mechanic hereWHERE I LIVE -not on this forum. sorry. <img src="/forums/images/graemlins/scared.gif" alt="" /> Well if you felt like bringing it to northern jersey I know of a few really good techs.
[Re: cuervo25]
#904051
09/21/08 08:55 PM
I upgraded my zj limited to bigger gears(front and back) and added limited slip to front end.
Mechanic did great job but didn't put abrasive additive into front diff and it pulled left and right.
Once we added it worked great!
PS: Most garages, JLube & EZ don't know about required additive and dont put it in. Most likely a mechanic drained and refilled diff without additive in back diff. Get kit which is like radiator test tube and test additive level or presume it contains none and ADD some until corrected...
Coach James
[Re: BigJim]
#904052
09/21/08 09:35 PM
I have a question to insert here... Does the female even KNOW what a fishtail is? Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" /> Hell Jim, I should hope so. Some women HAVE fishtails. Here's picture proof... <img src="/forums/images/graemlins/lol.gif" alt="" /> ![[Linked Image]](http://i295.photobucket.com/albums/mm127/bob8pics/Cancun-mermaid-tat-2.jpg)
[Re: 80CJ]
#904053
09/27/08 06:58 PM
I caught her once and threw her back. Too much bitc*in'. You had to see me get the hook out of her mouth! <img src="/forums/images/graemlins/drunk.gif" alt="" />
[Re: CoachJames]
#904054
09/27/08 07:00 PM
I had my wrangler diff lube changed at a 10 minute oil place against my better judgement. they talked me into it. Thats when my diff started leaking and making noises. never again.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.007s) Memory: 0.6298 MB (Peak: 0.7450 MB) Data Comp: Off Server Time: 2026-10-22 04:05:15 UTCValid HTML 5 and Valid CSS
