Re: POR-15 and NEW bed ...... [Re: philly] #904114 09/10/08 01:35 AM
CJM Offline OP
my "shutz gun" ..
2 wands .. first is a rotating 360* "V" notch . Second is a 90* rotating .
although the frame looks rough .. it is all surface , there are NO PIN HOLES .. NONE .. frame is good and strong ..
The pictures really dont do any justice to the work , looks much better in person ...
and about a leter of POR-15 was used ..
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904115 09/10/08 03:18 PM
Red_Chili Offline
Toyota Section Staffer
In my experience, POR15 without metal prep (and sometimes even WITH metal prep, if not done precisely) including their three step process doesn't adhere very well. Peels off in fact. One of the downers of POR15. How did you get all that done on the inside?
-Bill
Re: POR-15 and NEW bed ...... [Re: Red_Chili] #904116 09/10/08 03:48 PM
CJM Offline OP
absolutly I have had the same issues .. and obviously not possable to "scrub" the inside of the frame , but I have had some great results also , just applying to a cleaned , rusted piece .. with no pealing ..There is no "sure fire way"
I guess only time will tell for sure .
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904117 09/11/08 02:10 AM
CJM Offline OP
so got the new pump holder today , and got it all swapped
and tank back in place ..
rolled up the spare tire , and dropped the new fiberglass box on ..
83 Trekker SR5
NEW Trekker forum
Re: POR-15 and NEW bed ...... [Re: CJM] #904118 09/15/08 04:09 PM
Toy4x Offline
I replaced the FP bracket, later replaced the pump to find total rust on the bracket. I would suggest you POR the new parts. The original in your pic has the gold colored coating, the replacement does not.....
Re: POR-15 and NEW bed ...... [Re: Toy4x] #904119 09/16/08 02:11 AM
CJM Offline OP
YIKES !!!! thats ugly .
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 4.784s Queries: 16 (4.781s) Memory: 0.6150 MB (Peak: 0.7180 MB) Data Comp: Off Server Time: 2026-10-24 01:19:22 UTC
