Re: EURO, ***** & USA CAPS
[Re: OldColt]
#904357
03/11/09 04:20 PM
I haven't tried it but perhaps you could simply install a Europe instance of wincaps under c:/WincapsEur and the Japan wincaps under c:/WincapsJap, etc. Then change the configuration/setup screen for each instance to look for the data set in the corresponding directory. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#904358
03/11/09 05:00 PM
That sounds like the way. I have put each dataset in a separate folder in the wincaps directory. I guess a manual entry in setup to link each but am curious if there is a way to toggle directories such as with the F keys. I seem to be getting weaker in my DOS setups.
[Re: OldColt]
#904359
03/11/09 05:06 PM
Ahh, I think I might have it, the F8 key is CD switch.
[Re: OldColt]
#904360
03/11/09 05:17 PM
Outstanding Red Team! I will try all this as well. Assuming I can repeat across them, I'll look to add a ReadMe to the ZIPs I have posted up. May take me a few to get to it...
[Re: MontyMcV]
#904361
03/11/09 05:38 PM
I almost have it, i copy and pasted the path to each file, Caps did not seem to want the final directory included as it's original path shows. When I toggle I do get a different list of cars but I do get an error message about loading the CD. So I am close but not there yet. ![[Linked Image]](http://www.vermontel.net/~dcma/Caps1.jpg)
[Re: MontyMcV]
#904362
03/12/09 06:58 PM
Oh boy I did it now, Yesterday I had caps switching between data sets but not fully opening the other sets. It gave me the list of car lines but I could not get any further. Well today, I just opened Wincaps and it opened in Japenese. Humm, so I opened the setup, easy since it is the bottom of the file column. Fine but it gives me a different selection and all in ???????. It will not convert languages. I guess I will be a bit delayed in getting todays parts order called in.
[Re: TOASTY]
#1079316
10/16/15 03:46 AM
apparently doesnt work with 64x windows, working on fix
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank. 93 600 Katana. stage 1 jet kit, Uni foam air filter 02 honda shadow. "for when the woman wants to go with" 97 Acura Integra.
[Re: mynion]
#1079319
10/16/15 05:19 AM
ASA Version 1.3.0.2 working fine on windows 7 x64 for me
1990 LWB RS A/T 1990 LWB Base A/T 1991 LWB LS A/T Going...Going...
Re: EURO, Japan & USA CAPS
[Re: TOASTY]
#1104302
04/29/18 01:58 AM
Hi All, Is the Mitsubishi CAPS/ASA program still available? I cannot seem to get any of the downloads or links to work?
