22R Valve Guide Seal Replacement?? #904574 09/08/08 06:07 PM
SALMONHEAD Offline OP
So I've heard you can replace the seals without pulling the head. Does anyone have any information on this procedure?
Thanks
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: 22R Valve Guide Seal Replacement?? [Re: SALMONHEAD] #904575 09/08/08 06:39 PM
ACES_HI Offline
It was posted here a few years back. Do a search. IIRC it involves using compressed air in the spark plug holes to float the valves up.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: 22R Valve Guide Seal Replacement?? [Re: SALMONHEAD] #904576 09/09/08 01:32 AM
So I guess I got ahead of myself on this. The symptoms are some blue /grey smoke at start up and idle after it has sat for a few hours. It does not seem to miss out and seems to idle smoothly after I rev it a little to clear the plugs.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5903 MB (Peak: 0.6432 MB) Data Comp: Off Server Time: 2026-07-09 21:40:34 UTC
