Power antenna mast repair........ #904596 09/08/08 08:38 PM
crasherbean Offline OP
The mast quit going up and down. I took it apart and the plastic track is broken (the motor works fine). What is the best way to get into the fender without f-ing up the inner fender? I don't have a trim tool. [
Re: Power antenna mast repair........ [Re: crasherbean] #904597 09/10/08 02:33 AM
Edy Offline
I'm not sure you need to get into the fender. If you have all the plastic corrugated strip out just buy a new antenna and get a friend to help. With no antenna in the hole, put the new plastic end down in it with the stereo ON, then have the friend turn the stereo OFF while you push the plastic strip in. The motor gear should catch and suck the strip down. Of course you have to mess with the mount but that should be fairly straight forward.
85 4Runner 22re, mostly stock. Over 340K miles(SOLD for $4000 7/06)
98 2.7 4cyl 4Runner Bone Stock perfect 200,000 miles (alright, it has a HG and clutch in it's past)
Re: Power antenna mast repair........ [Re: crasherbean] #904598 09/10/08 02:43 AM
kewlynx Offline
Likely need to go at it via the fender liner
http://www.4runners.org/writeups/whip/index.html
I'm looking into this mod later on for myself.
There's also a 2000 FSM over in the sticky in the Taco section.
**ubi apis- ibi salus**
Re: Power antenna mast repair........ [Re: Edy] #904599 09/11/08 09:48 PM
Thanks! The plastic broke off inside of the motor, so I had to take the motor out and pull it apart and remove all of the old plastic. It was very easy to put the new antenna in, as it sucked right down AFTER I removed the old plastic!
Re: Power antenna mast repair........ [Re: crasherbean] #904600 09/23/08 05:53 AM
Darryl Offline
after my power one finally snapped...I put in the whip. MUCH better! Kinda tough to get at through the fender but that write up should help. Plus pulled out the motor and sold it on ebay for twice what the whip cost me <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6072 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-10-22 00:20:57 UTC
