1986 toyota 4x4 22r carberated, smoking from tail pipe
#904652
09/09/08 03:03 AM
took my truck muddn. had no problems the next morning I drove it 1/4 mile to the store got gas for the lawn mower and put gas in my truck out the same nozzel. got home pressure washed the truck, motor and all. let dry for about 2hrs. when I fired it up at idle every thing seemed fine. except for a slight skip. When on the gas It was smoking out the exhaut pipe pretty bad(grey/white). the more I got on the gas the worse it got. Same driving. There is no abnormal noise from the motor.Not runnig hot. rebuilt motor 6 months ago, new head. any ideas?
Re: 1986 toyota 4x4 22r carberated, smoking from tail pipe
[Re: neck86]
#904653
09/09/08 04:57 AM
white smoke is water, blue smoke is oil, and black smoke is gas. If it has a little miss or 'skip' to it, you probably just got a little water down the carb, and it should run out. If the skip persists, you may have a little moisture inside your distributor cap. Just take it off and clean it with ether and let it dry out...COMPLETELY DRY. That should take care of moisture.
If a man throws a wrench and no one is there to see it; does it still count as pitching a fit?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5878 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-06-09 21:49:03 UTCValid HTML 5 and Valid CSS
