rims for 99 sportage #904794 09/10/08 02:29 AM
O
odey Offline OP
does any body now if 16 inch rims will fit and if the rims will need to be off of a ford or jeep or what
99 kia sportage 2 door tj coil spring rear spacers in front 31x10.5 sidewider tires cat exaust in the process of making a snorkel
Re: rims for 99 sportage [Re: odey] #904795 09/10/08 04:40 AM
DennisThompson Offline
Your lug pattern is 5 on 5 1/2, The same as pre 97 F150s, Jeep CJs, Dodge 1500s, and a few others. The stock Ford wheels will not fit though, the hubs on the Kia are bigger and the center hole on the wheels are to small. I have been told that Dodge 1/2 ton wheels will fit though I'm not sure. If you find a 16" wheel (after market or some factory wheel) with the right lug pattern that fits over the hub it will work on the Kia. Try to find one as close to the Kia back spacing to keep you tires from sticking out unless thats the look your going for.
Hope this helps, Dennis
Re: rims for 99 sportage [Re: DennisThompson] #904796 09/10/08 07:54 PM
logansportage Offline
The center hole in the KIA wheels is 3 7/8.
Re: rims for 99 sportage [Re: DennisThompson] #904797 09/11/08 10:03 PM
O
odey Offline OP
i would not go to 16 but i have had a brand new set of co-op grip spurs setting i my garage for about 5yr so i figured time to use them or sell them
does any one know were to get lockout hubs for the kia does tracker lock out hubs interchange
Re: rims for 99 sportage [Re: odey] #904798 09/11/08 10:59 PM
sportagebandit Offline
get the warn manual hubs p/n 60247. you can get em for about 120, google em.
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: rims for 99 sportage [Re: odey] #904799 09/15/08 04:34 PM
Yankee_Tim Offline
Sell them. Tire manufactures (Europe) recommend tires be REPLACED within 6 years of manufacture date, as the rubber degrades regardless of use and could cause blow out.
Suzuki Grand Vitaras and XL7s are 5 on 5.5" and 16" to 17" rims
Yankee Tim
Re: rims for 99 sportage [Re: Yankee_Tim] #904800 09/15/08 05:48 PM
Hydra747 Offline
Then I pitty the poor guy who gets them <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: rims for 99 sportage [Re: Hydra747] #904801 09/17/08 02:09 PM
Yankee_Tim Offline
caveat emptor
<img src="/forums/images/graemlins/smile.gif" alt="" />
Yankee Tim
Re: rims for 99 sportage [Re: Yankee_Tim] #904802 09/19/08 03:47 AM
Hydra747 Offline
caveat emptor
In English?
Re: rims for 99 sportage [Re: Hydra747] #904803 09/19/08 01:07 PM
homerdog Offline
caveat emptor
In English?
Let the buyer beware.
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6327 MB (Peak: 0.7418 MB) Data Comp: Off Server Time: 2026-06-07 04:50:44 UTC
