Injectors #905311 09/13/08 10:48 AM
Superman Offline OP
I took my car to the dealership today to get a 60k tuneup. I got the oil+filter, air filter, sparks, radiator fluid, transmission and several other stuffs changed.
Half way through, serviceman called me and told me I have dirty injectors and they need to be cleaned for about $200.
Is that a reasonable price? He also said something else needs to be cleaned too, I think the throttle if I did not mishear him.
So, can I buy a fuel injector cleaner like Seafoam or Lucas to do the job? I am getting mix recommendations because some said cleaners does not work and other said they do.
Finally, why do injector gets dirty? If I start using Chevron instead of Shell, will that help?
Clark
Tacoma PreRunner Double Cab V6 Automatic
3.4-liter V6 TRD
Re: Injectors [Re: Superman] #905312 09/15/08 01:00 AM
Mark in AZ Offline
Toyota Moderator
A lot of the dealers use BG Products. You might find an independent shop in your area that will do it for less. I had mine done a couple years back, but don't remember how much it was (at an independent)...didn't really notice any difference in driveability. I have used their 44K product many times. Also have used Techron cleaner too. I use one of those two every time I change the oil.
http://www.bgfindashop.com/locator/index.php
Exploring in a T4R Ltd V8
Re: Injectors [Re: Superman] #905313 09/15/08 02:01 AM
kewlynx Offline
If they are pulling them, cleaning them, and rematching them, then yes, $200 is reasonable. If they are just tossing some BK fluid in there, then NO.
T'body you can do yourself. Article is similar for the 22RE.
T'body cleaning
**ubi apis- ibi salus**
Re: Injectors [Re: Superman] #905314 09/24/08 07:27 AM
Superman Offline OP
Does those injector cleaners work? If I use those, would I still have to take to the mechanic and do them or replace them? Can this job be done by yourself or it is too time costly or impossible like a timing belt to do at home?
kewlynx, thanks for the throttle cleaning. Is it that easy?
Clark
3.4-liter V6 TRD
Re: Injectors [Re: Superman] #905315 09/24/08 12:47 PM
ACES_HI Offline
At 60k you shouldnt have to pull the injectors and clean them. Unless you are experiencing driveability or poor mileage problems, I would buy a can of Toyota injector cleaner and add it to the tank with only a couple of gallons left in the tank so the cleaner is more concentrated. This stuff works but costs $10 a can. I just put in one can a year and I've had no problems.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6081 MB (Peak: 0.6732 MB) Data Comp: Off Server Time: 2026-11-03 04:53:44 UTC
