could it be time for a new clutch master Cylinder #905323 09/13/08 09:09 PM
brentox Offline OP
The clutch in my 92' has always required that I press the pedal ALL the way to the floor to place it into gear from a dead stop. When going into reverse it wants to grind just a little even when fully depressed. When I got this truck it was not running, so I have no idea how it was before. I put in a new clutch, t/o and pilot bearing and slave cylinder when putting in the "new" engine. The new clutch assembly has about 5k miles on it. It has always required the full depression but I just got used to it, because I usually just drive it on the weekends. But after a full day of driving it in traffic I thought that this is just not right, maybe I need a new master cylinder for my clutch, it does not leak but it is the only thing I can think of...its the original and the truck has about 190K miles on it....
any thoughts?????
92 Extended Cab 4x4, 3.0 5-Speed Scratched, Dented and Rusted.
Re: could it be time for a new clutch master Cylinder [Re: brentox] #905324 09/13/08 11:23 PM
P
PETE_YK Offline
Check the free play in the peddle, not sure off hand what its supposed to be, somethin like 1/8" to 1/2?...
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
PHP: 7.4.33 Page Time: 1.496s Queries: 15 (0.004s) Memory: 0.5882 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-10-24 03:24:16 UTC
