Tune up parts . Does Toyota's require stealership parts or not #905409 09/14/08 01:40 AM
Hackattack Offline OP
I am getting ready to order new spark plug wires, spark plugs, rotor & cap for my 94 4x4. I have always been told by Toyota mechanics that you must use toyota tune up parts or you will be sorry. Has anyone found this to be true?
Toyota T100 best truck Toyota ever built "Its so good the frame does not rust in half"
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: Hackattack] #905410 09/14/08 03:38 AM
Adam F Offline
Yes, Toyota OEM parts are the best.
Plug wires are expensive, so if it were me, I'd do a continuity test and look them over good, and if they check out, re-use them.
97 4R, stock, daily driver
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: Hackattack] #905411 09/14/08 06:00 AM
Snowtoy Offline
It depends on what you are replacing. Cap/rotor, no, spark plug wires, not really. Oem will last you a lot longer than Napa/Kragen, but is it worth the extra price, only you can answer that.
When it comes to sensors, thermostats, coils, alternators, starters, than yes only use Toyota, especially for sensors and thermostats. Coils. alternators, starters, etc., are like the plug wires, wont last as long.
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: Snowtoy] #905412 09/14/08 07:17 AM
IceBlueT Offline
snowtoy's right. i see alot of people try to save money by buying cheaper parts through the major parts chains, but end up spending more by bringin it to us when it doesn't turn out working right. it makes people kinda angry when they bring their freshly tuned up car in complaining of slight issues, then i turn around an recomend the same parts that they just replaced. i dont like doin it, but it usually fixes it. i would never recomend using any type of sensor other than stock, same with electrical items, because chain stores usually develop a part, and then duplicate them for different makes and models. i'm kinda kickin myself in the butt right now, because my autozone alternator is starting to give me issues, and its only been on there for 20k. i wish now i woulda bit the bullet and bought an oem for another $40, but oh well, to late now.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: IceBlueT] #905413 09/14/08 03:37 PM
P
philly Offline
last week i want through the part number thread and ordered up a bunch of crap from https://www.1sttoyotaparts.com/ they offer like 20% off i think. great deal. and when you can find the part numbers yourself it saves time dealing with local toyota parts counters (mine sucks)
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: Hackattack] #905414 09/15/08 01:55 AM
kewlynx Offline
x2 what Snowtoy said.
With where I live, by the time 1sttoyotaparts sends anything, I'm better off hitting up our parts people at the dealer here. Thankfully no idiots work there. <img src="/forums/images/graemlins/smile.gif" alt="" />
**ubi apis- ibi salus**
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: Hackattack] #905415 09/21/08 09:28 PM
toyomorph Offline
Absolutely! Tune up parts from Toyota are the best. I have run off brand plug wires and cap and roter but they don't FIT or last like OEM parts. Toyota, Nippondenso or Denso is tops. A while back I went to AZ and got a starter in a hurry. It went TU in about a year, then I had to find another stock starter off of the bay, and even used it is still working fine. Now gears and parts of the drivetrain are a different story. There are lots of good parts out there. I use Timken bearings. I think the old saying "ya get what ya pay for" is pretty true.
canyon country explorer
1993 4x PUP
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: Hackattack] #905416 09/23/08 03:46 AM
missouriman Offline
I would rather tune up my truck with toyota parts from the junk yard then by the cheap after market stuff..
I really do mean this.
alt, starters, even cap and wires if they are in good shape.
the only plug wires that I have had go bad got physically damaged.
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: missouriman] #905417 09/24/08 01:02 AM
1
1986xtracab Offline
I personally work at a Toyota dealership ( Downeast Toyota in Brewer, Maine) and I don't know home many times We've seen a car/truck come in running rough and the only problem was crappy plug wires. This is how good factory Toyota wires are, a few months back a 1988 pickup came in for a cooling leak, the truck still had the ORIGINAL 1988 plug wire, yes they are dated, and the thing ran like a top.
1986 xtra-cab 22re
stock everything
1991 bed
Re: Tune up parts . Does Toyota's require stealership parts or not [Re: 1986xtracab] #905418 09/24/08 08:51 PM
suba Offline
For me it usually comes down to how hard the part is to get to. Plugs and wires I usually just get the generic cheap ones, but then again I replace mine often (every other year about) just for the piece of mind. Usually my guideline is: if I don't want to have to do it again, I get a toyota part, if its something I do a lot, I go generic. Things like hoses (pcv, idle air, etc) that are on the top of the engine I feel should definitely be toyota even though they are easy to get to for several reasons:
1) The ones on my truck were 22 years old, and still in good shape so I figure these should last just as long.
2) Perfect fit means less skinned knuckles installing things.
3) Only cost a few bucks more, granted if you do a lot of parts it adds up.
One thing you can be sure of though, if you go with toyota parts you won't regret it, with generic parts it could go either way.
86 4runner, pro comp AAL, Kayline Soft top, 31's but all stock
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6438 MB (Peak: 0.7650 MB) Data Comp: Off Server Time: 2026-07-09 21:14:35 UTC
