L200 4D56T Engine upgrade #906098 09/18/08 08:00 PM
N
nexo Offline OP
I like to know if there's is a wise way to upgrade my 4D56 Turbo Intercooler (100 hp/245 Nm) engine ? If the answer is yes here's the questions about what kind of modifications should I take to get the significant - reliable result :
1. Upgrade the stock (Garrett TD04) turbo charger with a bigger one ? If yes I need the type of the bigger turbo that recommended for 4D56; or/and
2. Porting & Polish the valve, cylinder; or/and
3. Upgrade the exhaust; or/and
4. Install Water Methanol Injection (Snow Performance); or/and
5. Can I change the head with Common Rail DI-D ?
6. My 4D56T came with mechanical injection, can it change with electronic injection so I can use Dastek unichip ?
Thanks for the advice guys, I really need it.... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: L200 4D56T Engine upgrade [Re: nexo] #906099 09/19/08 07:28 AM
4ePajero Offline
This will certainly increase output, but these engines are not renowned for handling increased boost very well. Expect reliability issues.
Not worth it. Polishing and porting is for high revving engines.
This gives some improvement.
Dunno.
I doubt it, unless you add all the electronic bits.
No, there is no ECU to re-map.
Summary: The 4d56T is a hard worker. If you want a performer, get a later generation TD or a petrol engine. Diesels are not as easy to "upgrade" as petrols.
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: L200 4D56T Engine upgrade [Re: nexo] #906100 09/19/08 08:10 AM
Glock24 Offline
I've read that propane injection gives a good performance boost and also gets you better mileage, but have never seen it. Search the diesel forum for "propane", and you'll get some info.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
Re: L200 4D56T Engine upgrade [Re: 4ePajero] #906101 09/19/08 03:15 PM
N
nexo Offline OP
Thanks for giving me some opinion... Well, its not as easy as I thought. I think modified the exhaust is the safe one and adding cold air intakes ?!
Re: L200 4D56T Engine upgrade [Re: nexo] #906102 09/19/08 06:08 PM
redbull Offline
Exhaust is the simplest and probably least expensive modification. After that, things get more complex and expensive. I'd go for an intercooler upgrade next, then possibly a different turbo. I don't know much about selecting the best size turbo, so I'd spend a lot of time researching before I went that route. "Cold air" intakes are probably not worth your time on this truck.
Finally, a propane injection system that was set to come on at a certain throttle opening or boost pressure would help with hills, passing and towing. Lots of howtos online and commercial kits that could be adapted. But, again, lots of research before hand.
I'll probably never do more than the exhaust upgrade.
Re: L200 4D56T Engine upgrade [Re: redbull] #906103 09/20/08 11:02 AM
drtydzl Offline
Wow I really cant believe some said the following "Summary: The 4d56T is a hard worker. If you want a performer, get a later generation TD or a petrol engine. Diesels are not as easy to "upgrade" as petrol's." Your right the 4d56 is a hard worker. But the hole Diesels are not as easy to upgrade as petrol's it 110% WRONG. Dollar for Dollar diesels respond better to upgrade parts than there petrol brothers. My 4d56 has been running 25PSI of boost for 6 months now with out a issue, it has a home made snorkel, and a custom made 3.5 inch exhaust. And the best part is im back into the 20-25 MPG range with 35 inch tall BFG MT's. I would put my 4d56 up against any other petrol version any day of the week and i will make more power, get better mileage, and have less trouble doing it. There is nothing more reliable than a simple diesel. O yeah in case i forgot i run used fryer oil in my truck to at a 50/50 blend and am getting ready to install a new intercooler or add a second stock style intercooler.
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED
1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW
CURRENTLY LOCATED IN JAPAN
Re: L200 4D56T Engine upgrade [Re: drtydzl] #906104 09/21/08 03:26 AM
redbull Offline
I was hoping you'd post here.
Could you tell us what you are using for a turbo?
Re: L200 4D56T Engine upgrade [Re: redbull] #906105 09/21/08 05:07 AM
drtydzl Offline
What do you mean you were hoping that id post here. Im using the STOCK turbo. I have pictures of my gauge hitting 27PSI today but i can never get them to resize so i can use them as an avatar. If you got any other questions or concerns let me know.
Re: L200 4D56T Engine upgrade [Re: drtydzl] #906106 09/21/08 07:56 AM
PHIL_ Offline
Today:
Three months ago:
06/02/08 05:11 AM
HEY IM BUMPING THE BOOST ON MY 89 2.5L IM SETTING AT 15 PSI RIGHT NOW ANY IDEAS HOW HIGH I CAN GO SAFELY I WOULD LIKE 20 PSI
<img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: L200 4D56T Engine upgrade [Re: PHIL_] #906107 09/21/08 08:42 AM
4ePajero Offline
I am amazed that the stock turbo can boost to 27psi.
Standard is around 9psi?
My Di-D boosts to 19psi but has a lower compression ratio - only 17:1.
I doubt the longevity of the 4d56 running at 20+psi, and stick to my guns that I would not advise it.
Do you have an EGT guage fitted on the exhaust, close to the head? What temps do you run?
PS That's my opinion, and it is worth what you paid for it.
2" Lift
Front Runner Rack
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6420 MB (Peak: 0.7681 MB) Data Comp: Off Server Time: 2026-06-09 22:00:37 UTC
