valve cover vent hose #906583 09/21/08 11:18 AM
drtydzl Offline OP
Hey has anyone out there moved the hose that goes from the valve cover to the turbo intake hose. Also is anyone else's spewing oil into the turbo. Took mine out since i made my snorkel and routed it into a 1 quart oil bottle. has anyone else done anything else different to keep all that bad oil out of the turbo let me know thanks.
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED
1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW
CURRENTLY LOCATED IN JAPAN
Re: valve cover vent hose [Re: drtydzl] #906584 09/22/08 02:11 AM
Kurt1230 Offline
It is an oil cooled turbo... where is the confusion ???
If you were worried about 'bad oil' getting into the turbo then you shouldn't have bought a diesel as they run dirty.
Oil and filter every 5,000kms and you'll be fine. As far as the 'quart bottle bypass' I commend you for trying, but I think its a bit much.
<img src="/forums/images/graemlins/confused.gif" alt="" />
1990 Mitsubishi Pajero 2.5tdi NG
31" Dueler A/T
Winter pack
Bright Lights
Re: valve cover vent hose [Re: Kurt1230] #906585 09/22/08 08:52 AM
4ePajero Offline
I presume you are referring to the positive crankcase ventilation?
Sure you can re-route the pipe into a bottle, but then your engine is violating emission regulations in just about every state and country in the world.
Why not fit a Raco CCV4500 crankcase ventilation filter (or similar) and stay inside the law?
If your engine is in good nick, the oil content in the ventilated air should not be not that much, IAC. Maybe that high boost turbo is effecting your engine?
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: valve cover vent hose [Re: 4ePajero] #906586 09/22/08 12:14 PM
drtydzl Offline OP
I was thinking that the boost level was some what to blame that seems to be the only side affect i have noticed so far pictures should be view able now let me know snorkel pics to come this weekend
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6009 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-05-29 22:42:56 UTC
