Re: Do glow plugs work but l loose efficiency? [Re: vlad4d56] #906738 09/24/08 06:34 PM
I
inokiyo Offline OP
How did you measure the resistance of all 4 plugs?
Try to clean the plate that connects all the plugs, maybe you have a bad contacts here.
But anyway, at +15 engine should start easy, even you have no plugs at all. I would check the injectors. If injector doesn't spray properly (leaks), the cold engine can't burn the fuel. When temperature rises the engine is able to burn anything the injectors supply. It seems similar to your condition.
I took out each plug, and measured resistance with a digital multimeter. I made sure the contacts were good by etching the points onto the plug. I also cleaned the bus bar plate, wire brushed all contacts including the wires.
I'm planning on swapping glow plugs off a good starting Pajero onto mine and see if that improves anything.
BTW, have any of you heard of modifying the 4d56 glow plug module to a modern delco or bosch system?
Re: Do glow plugs work but l loose efficiency? [Re: inokiyo] #906739 09/25/08 01:06 AM
torquemonster Offline
Thanks for the quick response torquemonster! I think I saw your truck at the IVOAC M&G. Was that you?
yes that was me there. before the soccerball sized rock in the windshield and the hail damage haha.
Re: Do glow plugs work but l loose efficiency? [Re: torquemonster] #906740 09/25/08 03:10 AM
bae146 Offline
Hey Torquemonster did you ever get your windshield replaced? If so where from and how much?
Re: Do glow plugs work but l loose efficiency? [Re: bae146] #906741 09/25/08 05:31 AM
I
inokiyo Offline OP
Yeah, I'd like to know for futures sake too!
Re: Do glow plugs work but l loose efficiency? [Re: inokiyo] #906742 09/25/08 05:42 AM
I
inokiyo Offline OP
So I swapped out the glow plugs from a good cold starting pajero to mine and no improvements.
My glow plugs were all pretty much white/silver except for the section close to the taps which had soot. It was in near identical condition as the good Pajero's glow plugs.
We compared the timing of the clicks and they were exact. 1 click, 2 click, then 3rd click after a minute or two at normal idle.
The resisitance on the good Pajero's glow plugs were the same at 0.4 OHM.
...So I guess the glow plugs, ECU/glow plug controller and temp sensor is fine.
Next up is the intercooler clean up, then injector cleaning, then injection timing.
I'm pretty sure air leak in the fuel system would be written off as the truck runs fine when warm/hot.
Any thoughts in this?
Re: Do glow plugs work but l loose efficiency? [Re: inokiyo] #906743 09/25/08 03:55 PM
redbull Offline
How old is the fuel filter?
Re: Do glow plugs work but l loose efficiency? [Re: redbull] #906744 09/26/08 04:56 AM
I
inokiyo Offline OP
The fuel filter is probably original since I have not changed it. I never thought a dirty fuel filter would contribute to cold start issues?
Hmmm...but I guess it should be replaced anyways.
Thanks!!
Re: Do glow plugs work but l loose efficiency? [Re: inokiyo] #906745 09/26/08 09:19 AM
PartyTruck Offline
You should take another look-see under the hood. Some of the paj's have a timing advance and most of the gen 2's have it, it's easely recocnized by the 15mm coolant hoses coming from the side of the fuelpump. One goes to the back of the head the other one goes someplace I cant remember. If you don't have it there should be a almost circular lid with three bolt holes on the side of the fuelpump under the throttle assembly. These thing go bad for no reason and can be replaced.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Do glow plugs work but l loose efficiency? [Re: PartyTruck] #906746 09/27/08 06:26 PM
I
inokiyo Offline OP
Thanks! I'll check under the hood again and see if I can find it.
Cheers!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6326 MB (Peak: 0.7520 MB) Data Comp: Off Server Time: 2026-06-07 06:55:11 UTC
