1989 2.6l cyl head cracked #907003 09/24/08 02:08 PM
colozu Offline OP
I am needing info on a supplier to use for purchasing a replacement head. If any one can recommend a supplier to use I would appreciate it. (Online supplier or any in Denver Colorado.)
Re: 1989 2.6l cyl head cracked [Re: colozu] #907004 09/24/08 02:33 PM
Richard Saylor Offline
http://www.aluminumheads.com/Isuzu.html
Welcome. <img src="/forums/images/graemlins/cheers.gif" alt="" />
FYI, search is your friend. Just remember to change the dates so you get it all.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 1989 2.6l cyl head cracked [Re: colozu] #907005 09/24/08 04:04 PM
Trooper-san Offline
I went through the same process. I cracked the head on my '89 2.6, started blowing out head gaskets, and finally bought an AMC replacement head from those same people. The original head was a number 4 casting, but there were too many problems. It had cracks, the valves were burned. Take a look at the pictures in the link below.
I highly recommend the AMC head from these people. My dealings with them were good and very easy.
AMC Heads at Aluminum Head Rebuilders
The AMC heads are new, not rebuilt.
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: 1989 2.6l cyl head cracked [Re: colozu] #907006 09/24/08 08:03 PM
Ed Mc Offline
Be sure to use an OEM (Isuzu factory) replacement head gasket. Aftermarket ones don't seem to survive long-term.
Jerry Lemond or St. Charles Isuzu are good sources for parts.
"Accept No Substitutes"!!!
Cheers........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: 1989 2.6l cyl head cracked [Re: colozu] #907007 09/25/08 02:56 PM
colozu Offline OP
this helps thanks for the info.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6056 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-07-13 02:39:44 UTC
