4 runner air valve connections #907246 09/26/08 07:54 AM
Stairone Offline OP
I need to know where the hoses from the air value connect . I have an 86 4Runner with 22re. pics would be nice.
Re: 4 runner air valve connections [Re: Stairone] #907247 09/26/08 03:13 PM
Richards19884x4 Offline
I think you will have to be a little more specific on the term "air valve". There are several VSVs (Vacuum Switching Valves) on a 22re. I am assuming this is your reference to an air valve. Post a pic of which one you are having trouble with, and I'm sure we can help.
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: 4 runner air valve connections [Re: Stairone] #907248 09/26/08 03:49 PM
4Crawler Offline
Yes, which air valve you are referring to would help. Taking a guess that you are referring to the idle up air valve, there are some pictures on my web page of that valve and some of the other VSVs:
- http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/index.html
Re: 4 runner air valve connections [Re: Richards19884x4] #907249 09/26/08 04:25 PM
Stairone Offline OP
I know two of the lines go to water pump but i dont see where the hook up at on the water pump the other two go to the intake but where http://i99.photobucket.com/albums/l287/yota4life/00232.jpg
Re: 4 runner air valve connections [Re: Stairone] #907250 09/26/08 05:21 PM
4Crawler Offline
The two smaller coolant lines attach above and below the cold idle air valve, the large air line in front runs up to the side of the throttle body.
Re: 4 runner air valve connections [Re: 4Crawler] #907251 09/26/08 06:27 PM
Stairone Offline OP
yes but what I did was take a 22r engine out of my truck and i am putting it into my 4runner(22re) The 4 runner had no engine when i got it so i changed all the intake and tracked down most of the vac lines but I need a pic of where these go im not sure if i am missing something or not tried everywhere looked at hundred pics butr none of the valve hoses hook up locations
<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 4 runner air valve connections [Re: Stairone] #907252 09/26/08 08:02 PM
I have to change the oil this Saturday. If you can hang on, I'll take some pics while under the hood and see if I can take some that will help show the hose routing. That's about the best I can offer at the moment.
Richard S.
Re: 4 runner air valve connections [Re: Richards19884x4] #907253 09/27/08 05:52 AM
P
PCMentor Offline
My water hoses connected to rusty nipples one on the intake and the other on the Throttle body I think. The air hoses go one on the valve cover side of the plenum in the middle the other goes on the throttle body look for nipples large size.
Here's the air hose at plenum
Here's the air hose at TB
Re: 4 runner air valve connections [Re: PCMentor] #907254 09/27/08 02:11 PM
Stairone Offline OP
Thank you very much sir. The pictures on vac lines from 4crawler and these pics too are about the only useful information I have found. Thank you this whole web site has been a life saver <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thank ya both!!!!!!!!!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6276 MB (Peak: 0.7314 MB) Data Comp: Off Server Time: 2026-06-21 20:23:54 UTC
