synchromesh #907487 09/27/08 05:23 PM
8
85Montero Offline OP
is synchromesh ok for TC and MT?
thanks
Re: synchromesh [Re: 85Montero] #907488 09/27/08 05:55 PM
93montero_sr Offline
TC and MT?
torqe convertor and manual trans.?
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: synchromesh [Re: 93montero_sr] #907489 09/27/08 06:03 PM
8
transfer case
Re: synchromesh [Re: 85Montero] #907490 09/27/08 11:44 PM
Angelo Offline
I would think so. My VR4 that I got from someone used it cause of the slight griding it has when shifting on the fly into 2nd and 3rd. Synchromesh should help absorb some of that and help it shift a lil smoother, but wil not fix your problem in the long run. Its usually good for 10k. I plan on trying it out myself
Re: synchromesh [Re: 93montero_sr] #907491 09/27/08 11:44 PM
KrzyDav Offline
I would think of no advantage to Pennsoil Synchromesh.The t case is kinda primitive and I stil with 80-90wt.
Synchro has been used as additive to V6 V5MT1-0 s.
dave h.
Re: synchromesh [Re: KrzyDav] #907492 09/30/08 01:43 AM
8
it snchromesh supposed to be an additive or a full on lube to be used in place of other gear lubes?
Re: synchromesh [Re: 85Montero] #907493 09/30/08 07:45 PM
KrzyDav Offline
I used it as a fill , probably souldn't .
It is really watery
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6203 MB (Peak: 0.6940 MB) Data Comp: Off Server Time: 2026-06-18 13:14:54 UTC
