dash goes out #907555 09/28/08 01:57 AM
tcoff Offline OP
Driving to work the other day and my dash kind of went out. The check engine and airbag light goes on and the tech and speedo go dead. plus the milage numbers change to read "no bus". any ideas?
also it comes and goes.
thanks tom
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
Re: dash goes out [Re: tcoff] #907556 09/28/08 04:32 PM
Brown81CJ5 Offline
Sounds like something has come loose. Does it do this after hitting a bump for example?
I would get under the dash and check for any loose electrical connections. Also check the engine bay along the firewall...I believe the computer is on the passenger side of the firewall.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: dash goes out [Re: Brown81CJ5] #907557 09/28/08 11:46 PM
tcoff Offline OP
It just comes and goes, don't have to hit anybumps. But it's funny that when it did go out i was looking for pot holes to hit to see if it would come back on. i'll check the connections. But any ideas as to what the "no bus" means?
Re: dash goes out [Re: tcoff] #907558 09/29/08 01:47 PM
DBL_DTY97TJ Offline
The main cluster/ plug behind the dash is famous for that, particularly in '97's. Mine did it off and on for a while, but it turned out to be the main ground ribbon or some related connection that got fixed at the same time, so I never had to open it up and get in there. From what I understand it's a serious PITA. Good Luck.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: dash goes out [Re: DBL_DTY97TJ] #907559 09/29/08 05:18 PM
BigJim Offline
Yeah, everything going on and off at the same time would lead me to think a serious GROUND problem..
Re: dash goes out [Re: BigJim] #907560 09/29/08 11:01 PM
DBL_DTY97TJ Offline
From what I understand there is a big ol plug connection behind the instrument cluster that is infamous for coming loose. Apparently I was lucky it was a ground.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6094 MB (Peak: 0.6787 MB) Data Comp: Off Server Time: 2026-11-03 13:21:55 UTC
