Fuel Filler Hose #907710 09/29/08 02:46 AM
jas67 Offline OP
Can anyone lead me in the right direction to purchase the fuel filler hose that attaches to the gas tank? I have had no luck with Autozone, Carquest, Napa. It's for a '91 Montero. (Or is there some universal flex hose that can be used?)
Thanks!
Jeff
91 Montero west of the Pecos!
98 Shadow Aero 1100
Re: Fuel Filler Hose [Re: jas67] #907711 09/29/08 03:43 AM
Mitsu dealer.
I don't have your vin but based on my limited caps research, there are 3 possible parts depending on which part of the tube you mean.
The part physically attached to the tank is p/n MB554777 which is called a Fuel Filler Hose.
Then there's the next section which is noted as Fuel Tank Soft Vinyl Tube (60x1000) which is p/n MB129146
Then there's the Fuel Tank Hose which is shown as p/n MB595287.
HTH <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Fuel Filler Hose [Re: off-roader] #907712 09/29/08 04:12 AM
I, too, would recommend new. If you have sticker shock, I have two 91 parts cars that have these parts available. Dealer first with strong consideration, used second until you opt for the new parts. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Fuel Filler Hose [Re: rxinhed] #907713 09/29/08 04:27 AM
52degrees Offline
Mine leaks. <img src="/forums/images/graemlins/frown.gif" alt="" />
KG6VNX
Re: Fuel Filler Hose [Re: jas67] #907714 09/29/08 01:31 PM
hazy_daze Offline
2" wire reinforced fuel hose. P/N 1045 at NAPA. The smaller one is a ~3/4". I used a multi duty hose from NAPA as well. On the large hose, you'll need to cut the anti-chafe liner to get it to spread around the new hose. It's a slightly larger diameter than the old hose. It's flexy enough to make the bends. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
EDIT: Gave ya the wrong P/N. For the reinforced hose it's an 1130. Sorry.
Re: Fuel Filler Hose [Re: jas67] #907715 09/29/08 08:43 PM
ThatGuyFromGates Offline
I used a universal goodyear hose from Advance; had to order online, and it only came in 4 foot lengths, but I believe it was about 50 bucks or so. It was a pain in the arse getting to curve it around the frame, but it finally came together. I'm not sure if there are some brands/types that are more flexible, but the goodyear stuff is pretty tough.
Cheers,
JK
Re: Fuel Filler Hose [Re: ThatGuyFromGates] #907716 09/29/08 11:09 PM
KrzyDav Offline
I think I paid $38 bucks/ $10. shipping for my fill hose Mitsubishiparts.com. The hose is a grey "silicon"y" rubber.
I would not use anything for gas but OEM.
dave h.
Re: Fuel Filler Hose [Re: jas67] #907717 09/30/08 06:49 PM
jas67 Offline OP
Thanks guys for all the help. I used the part from Napa and it worked out fine.
Jeff
98 Shadow Aero 1100
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6245 MB (Peak: 0.7078 MB) Data Comp: Off Server Time: 2026-11-03 12:21:10 UTC
