slight high idle; 1983 yota, 22r w/carb
#908229
10/01/08 06:08 AM
Howzit, I recently noticed a higher rpm when I pull to a stop. somewhere around 1200+. If I tap the throttle, rpms goes back to norm (~900). I lubed my linkages and carb area but still the same. The return spring seems to have resistance. I thought it might be a vac leak, but again, once I tap the throttle the rpms drop. Any suggestions? Thanks.
Re: slight high idle; 1983 yota, 22r w/carb
[Re: flyinhawaiian]
#908230
10/03/08 05:58 AM
clean the inside of the carb with carb cleaner and spray the outside of it as well. Clean all linkages.
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5865 MB (Peak: 0.6342 MB) Data Comp: Off Server Time: 2026-06-07 07:22:33 UTCValid HTML 5 and Valid CSS
