Locate a Fuel Tank #908252 10/02/08 12:23 AM
Richards19884x4 Offline OP
After going through virtually all the parts sites recommended here on the forum, I can't seem to locate one of the 13.7 gallon fuel tanks for my short bed truck. In many cases, they show only one part number and don't even list the tank size. My short bed truck came with either a 14 or 17 gallon tank (52L or 65L) and I have the 14. Anybody know where I can purchase a new tank? Note that the friendly, helpful staff at the local National Tire & Battery is footing the bill since they decided to raise my truck with the shop lift with one of the arms directly under my fuel tank. <img src="/forums/images/graemlins/angry.gif" alt="" />
Richard S.
88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds
Proud to be an American. Blessed to be a Texan!
Re: Locate a Fuel Tank [Re: Richards19884x4] #908253 10/02/08 12:38 AM
4Crawler Offline
JC Whitney lists some replacement tanks...
And you can go with the larger tank if you want. It will hang down about 1" farther for the added capacity but otherwise bolt right up. And with the body lift, you could raise the tank up above the frame rails:
- http://www.4crawler.com/4x4/CheapTricks/DrivetrainLift/index.shtml#GasTank
Re: Locate a Fuel Tank [Re: Richards19884x4] #908254 10/02/08 12:39 AM
Staceman Offline
$259 at 1sttoyotaparts.com
I'd post a pic of my screenshot, but FTP is broke at work.
(1988 Toyota
OEM parts --> Fuel System --> Fuel Supply --> Fuel Tank)
Re: Locate a Fuel Tank [Re: Staceman] #908255 10/02/08 12:41 AM
Staceman Offline
Looks like $360 for the bigger one.
Re: Locate a Fuel Tank [Re: Staceman] #908256 10/02/08 12:51 AM
Thanks for the info, guys. I was unaware that the bigger tank would fit. As a side note, when I tried the toyoDIY parts lookup site, it ONLY shows the 65L tank, but the OE number doesn't match the numbers at a couple of the parts sites.
Now, does going to the 17 gallon tank mean I can still use my existing float gage and pump assy (i.e., will it fit the larger tank)?
Much obliged for the quick responses!
Richard S.
Re: Locate a Fuel Tank [Re: Richards19884x4] #908257 10/02/08 02:25 AM
4Crawler Offline
Not sure on the float or the pump bracket. It may need to have a taller bracket added onto the pump to sit at the bottom of the tank.
Re: Locate a Fuel Tank [Re: 4Crawler] #908258 10/02/08 02:35 AM
toyrunner Offline
Pump bracket for the larger tank is longer. You could use the shorter one and have a larger reserve. <img src="/forums/images/graemlins/smile.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Locate a Fuel Tank [Re: toyrunner] #908259 10/02/08 03:18 AM
Hmmmmm.... Seems like that reserve may only be available while going around a corner really fast if the pump won't reach it! <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
Richard S.
Re: Locate a Fuel Tank [Re: Richards19884x4] #908260 10/02/08 05:19 AM
RatLabGuy Offline
Keep in mind that your gauge may not read correctly too - I'm not sure about this.
I DO know that when I swapped my gauge cluster in my non-SR5 4Runner for the SR5 one, it changed; my guage now goes all the way to the botto, and stays there for another 1/4-ish of a tannk before the light comes on and it's actually empty. I'm guessing this is b/c it's calibrated for a smaller tank (I must have the 17 gal)
Question Reality.
Re: Locate a Fuel Tank [Re: Richards19884x4] #908261 10/02/08 04:58 PM
matts Offline
I bought my new tank from these guys Discount Gas Tanks It looks like the price was up to near $200 for a while but now they are offering it at $120!!!
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6431 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-07-14 05:03:07 UTC
