Blinking Cruise Control #908616 10/05/08 05:10 AM
Hugh Offline OP
When I tried to set my cruise control today, all that I got was a blinking light and no engagement.
Any suggestions?
Hugh
94' 4Runner SR5 3.0L, 4X4, 5-speed, 200K
01' Sienna XLE, 105K, auto everything...
91' Ford F-250, 7.3 liter IDI diesel, 5-speed, 170K
Re: Blinking Cruise Control [Re: Hugh] #908617 10/05/08 05:16 AM
Jeff the marmot Offline
I had a problem like that years ago when the brake pedal switch went bad. If I remember correctly, there's really 2 switch connections inside the brake switch - one for the brake lights and one to signal cruise control that you touched the brake, which disengages it immediately. You should try replacing the brake switch. That fixed it for me. I just remember it was a big pain to separate the wire plug-in from the switch. I had to use a screwdriver to pry somewhere on it. Check the new switch for where to pry. Be careful in case you don't have brake lights either.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Blinking Cruise Control [Re: Hugh] #908618 10/05/08 09:57 AM
ldivinag Offline
other is that the master brake fluid reservoir... there is a float switch in there that fails... well actually the switch is there to see if the level of the brake fluid is low.
if low, it's supposed trigger that symptoms you are experiencing right now.
but when that switch fails... well, same thing.
on my 90 4runner, i just disconnected that switch in the cap from the harness.
WARNING: that switch has a safety function. disconnecting that switch might not tell you when you have a massive loss of brake fluid.
the toyota dealer wanted something like $70+ for that new cap and switch...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Blinking Cruise Control [Re: ldivinag] #908619 10/05/08 09:43 PM
Hugh Offline OP
Thanks for the suggestions, I'll check it out <img src="/forums/images/graemlins/cheers.gif" alt="" />
I just bought a new back-up light switch yesterday to replace the original switch that stopped working.
--Hugh <img src="/forums/images/graemlins/mrt.gif" alt="" />
Re: Blinking Cruise Control [Re: Hugh] #908620 10/07/08 01:34 AM
Hugh Offline OP
Update: I replaced my worn out backup light switch yesterday $42 Toyota part with AAA discount...now I have backup lights again <img src="/forums/images/graemlins/kewl.gif" alt="" />
Blinking Cruise Control light problem has stopped blinking, yesterday it worked fine. Brake fluid level looks fine too, so I will investigate again when the blinking symptom returns.
Thanks much <img src="/forums/images/graemlins/patriot.gif" alt="" />
--Hugh
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6072 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-06-10 07:16:00 UTC
