Plugging brake lines #908850 10/06/08 03:13 PM
Kletzenklueffer Offline OP
Simple question- when ya'll doing axle work or stuff that requires disconnecting the brake lines, what do you plug them with to keep from losing fluid while you work?
Re: Plugging brake lines [Re: Kletzenklueffer] #908851 10/06/08 03:16 PM
Adam F Offline
Vacuum caps
97 4R, stock, daily driver
Re: Plugging brake lines [Re: Adam F] #908852 10/06/08 03:39 PM
RatLabGuy Offline
In the rear, there's a trick... follow the brake lines across the axle to the T where the R and L sides connect and go to the LSPV.
If you disconnect the line there, you can conveniently thread a std M10 1.25 bolt into that T on either/both sides, blocking it off. Yes you will lose a little from the line going into the wheel, but not much. I like threading something in better than the caps b/c it makes a "real" seal... if it's going to be of for a little while, and you were to forget it and jump in and press teh brake, this will hold pressure. The caps above will just blow off.
unf I can't help you on teh front, that hasn't come up for me (yet).
Question Reality.
Re: Plugging brake lines [Re: Kletzenklueffer] #908853 10/06/08 05:05 PM
Vacuum caps. Thank you. I had a couple, but didn't know what they were called (and I used to work in a parts store!)
Re: Plugging brake lines [Re: Kletzenklueffer] #908854 10/07/08 10:36 AM
TheBigDog Offline
Wooden golf tees also work a treat when you are stretched!
Excuses are for losers.
Re: Plugging brake lines [Re: TheBigDog] #908855 10/07/08 04:43 PM
OOP'S Offline
I took a couple of old rubber brake lines and cut the female ends off and brazed them shut.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Plugging brake lines [Re: OOP'S] #908856 10/07/08 08:13 PM
missouriman Offline
dang guys.. all it takes to keep the fluid from running out.. on a short repair is a Q tip broke in half and shoved up into the line. stick part first. it will drip a bit. but will keep the fluid from just pouring out.
Re: Plugging brake lines [Re: missouriman] #908857 10/08/08 02:59 AM
RatLabGuy Offline
I used a glob of chewing gum once too. Still leaked a little but did the job temporarily!
Question Reality.
Re: Plugging brake lines [Re: missouriman] #908858 10/08/08 04:14 AM
OOP'S Offline
Most of mine are not short repairs, for short repairs, I use vacuum caps. Used a pencil once and the dang thing broke off and the brake on that side did not work very well.
David Fritzsche
Roseville, CA
Re: Plugging brake lines [Re: Kletzenklueffer] #908859 10/08/08 10:37 PM
missouriman Offline
Q tips work well also.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6383 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-07 09:12:07 UTC
