2.6l rocker shaft assembly #908946 10/07/08 04:27 AM
Chris009 Offline OP
All,
After 2 bad heads from the rebuilder, I get #3. It looks good. I have it installed.
20 miles or so down the road, I hear expensive noises from the top of the engine. Back to the mechanic. Here is what we find:
http://digitalpics00.no-ip.org/~halatos/Engine100608
What I noted immediately is that two of the exhaust rockers had migrated forward and were touching the intake rocker tips, resulting in the expensive sounds. As best I can tell, no damage has been done so far. But it is apparent that the head was assembled incorrectly and the wrong springs were used.
Can anyone tell me if the exhaust rocker shaft is supposed to have different length/wire diameter springs from the intake? It looks like the exhaust springs would need to be longer/stiffer to do the job, and I think the guy who built this head mixed them up.
Thanks,
Chris
Re: 2.6l rocker shaft assembly [Re: Chris009] #908947 10/07/08 07:35 PM
88 parts manual shows only one type on both sides, MD021211. However, I don't see any wave washers that also go on the shaft which would take up some slack. May have also used a spring that had been severely overheated and lost tension. May also have a cam with non-flat lobes, making the rocker walk sideways. Looks like a crap rebuild. Rocker slipper may also be worn on one side, for same side-walk.
Re: 2.6l rocker shaft assembly [Re: fasteddy] #908948 10/08/08 12:20 PM
TainterRacing Offline
what he said need new springs and you need the washers and same deal on the cam. make sure its a hdy cam.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: 2.6l rocker shaft assembly [Re: TainterRacing] #908949 10/08/08 06:41 PM
mxmikie Offline
i have a set of roller rockers for that i prolly have the springs and washers also
Re: 2.6l rocker shaft assembly [Re: fasteddy] #908950 10/09/08 04:23 AM
Kevin C Offline
Good points.... Also a cam with a taper ground into the face will do the same thing.
Kevin C
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6076 MB (Peak: 0.6729 MB) Data Comp: Off Server Time: 2026-06-20 18:31:10 UTC
