broken timing belt #909004 10/07/08 03:21 PM
v0d Offline OP
Hey guys, I need some advise.
My timing belt broke while driving down the highway. How do I tell if the engine or head is in a bad way (other than opening it up)?
I'm told the valves could be bent..but then I've read that this could be a "non-interference" engine and that replacing the belt might be all that it needs.
Have any of you guys been through this?
Darth Montero - 1991 LS, with 31" Geolanders on black steel. 172k miles.
http://www.cardomain.com/ride/2939365
Re: broken timing belt [Re: v0d] #909005 10/07/08 06:09 PM
If it's the SOHC 3.0L v6 for a gen I (up to 91) then from what I understand it should a non-interference engine and changing the belt is all that's needed. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: broken timing belt [Re: v0d] #909006 10/07/08 06:10 PM
87Montero Offline
If its the stock 6G72 (3.0l) from the Gen 1, you'll be ok.. just slap another timing belt on and go.. Don't forget to replace the waterpump, idler pulleys and drivebelts to make the job complete and pat yourself on the back for a job well done and that you've dodged the bullet this time. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: broken timing belt [Re: 87Montero] #909007 10/07/08 06:11 PM
Tensioner pulley as well and if it's leaking or old, possibly even the front seal.
Re: broken timing belt [Re: off-roader] #909008 10/07/08 06:50 PM
v0d Offline OP
where do I find that engine code at?
The vin has "S" which is 3.0L 184.4ci.
Re: broken timing belt [Re: v0d] #909009 10/07/08 07:40 PM
Trust me, you have the non-interference engine. You lucked out.
Re: broken timing belt [Re: off-roader] #909010 10/07/08 07:54 PM
87Montero Offline
All that goes without saying.. Do it right the first time! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: broken timing belt [Re: v0d] #909011 10/07/08 09:54 PM
KrzyDav Offline
Get a Mitsu Brand front main seal,,,,Get the improve harmonic balancer/ crank bolt and use the update torque on it...it's like 130 ft lbs instead of 85ft lbs.
dave h.
Re: broken timing belt [Re: KrzyDav] #909012 10/07/08 11:34 PM
dannytuned Offline
my '01 24v 3.0 IS an interference motor. a 10mm nut got under my timing cover and took out the crank sensor, belt jumped, instantly bent every intake valve. $800 in parts and machine work. <img src="/forums/images/graemlins/shiner.gif" alt="" />
see my broken o.m.e. shock in the pic <img src="/forums/images/graemlins/lol.gif" alt="" />
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: broken timing belt [Re: dannytuned] #909013 10/08/08 01:29 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> Niiiiice! <img src="/forums/images/graemlins/kewl.gif" alt="" />
I need to do my belts. I'm sure I'm flirting with disaster myself. <img src="/forums/images/graemlins/scared.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6380 MB (Peak: 0.7468 MB) Data Comp: Off Server Time: 2026-06-07 05:44:14 UTC
