Page 1 of 3 1 2 3
differential lockers #909285 10/09/08 05:00 AM
kiaracer Offline OP
anyone running differential lockers in the front and rear diffs? i'm gonna be getting a 98 sportage next week and i would like to start researching some 4x4 parts for it.
2000 Kia Sephia, 1998 Kia Sportage 4x4, 2002 Kia Sportage 4x4
Re: differential lockers [Re: kiaracer] #909286 10/09/08 08:38 PM
logansportage Offline
The only lockers available are out of Korea. You can get an Eaton LSD for the rear, but the front you are SOL.
There are rumors that the 96 LSD for the rear will fit the front with some trimming of the housing. This has yet to be completely confirmed.
There are also rumors that a Mazda Miata LSD will also fit the front, but this too has yet to be completely confirmed.
Re: differential lockers [Re: logansportage] #909287 10/10/08 12:39 AM
DEFBOY35 Offline
did anything ever happen with the greece guys lockers?
and welcome to the forum. there is a lot of info here. best thing i did, was went through and read almost every post in this section to learn as much as i could then asked questions when i didnt understand something!
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: differential lockers [Re: logansportage] #909288 10/11/08 05:48 AM
kiaracer Offline OP
not really looking for an LSD i don't think. i need an actual differential locker that is either air, electrically, or manually actuated. i want one for both front and back diffs. any idea if there is a site selling them out of korea? i may be able to talk to a couple aftermarket parts importers and see what they can get.
Re: differential lockers [Re: kiaracer] #909289 10/11/08 09:13 AM
fokion Offline
The Greek differential is still availiable but afaik the production is slow.
and it fits only lower RP gears of 5.3, they ara sold as a set..
Re: differential lockers [Re: fokion] #909290 10/12/08 02:09 AM
DEFBOY35 Offline
i was unaware that there was r& p gears, or i would have bought them along time ago. a little late for this truck now, but might be picking up a 2nd sporty that will be keeping the IFS, but a new long travel system
Re: differential lockers [Re: DEFBOY35] #909291 10/12/08 06:32 AM
kiaracer Offline OP
that's one thing i want to do as well. i would like to get more flex out of the front end because from what i understand cv axles don't like to be flexed very far and i would like to try to avoid swapping in a solid front axle if i can.
Re: differential lockers [Re: kiaracer] #909292 10/12/08 10:47 PM
Dave Scott Offline
the Miata LSD works in the front. it is confirmed. for over 2 years now.
you can get more flex in the front if you drop the top strut mount 1" and cut 2/3 of the bumpstop out.
the Eaton LSD is the only thing available in the US for the rear.
most US models came with 4.78 gears and there is nothing lower available here.
the 5.38 gears and greek and korean lockers have to be purchased from those companies and may require some sort of translation. so far, i have not seen suitable translation nor have been able to suitably communicate with either of them....
Re: differential lockers [Re: Dave Scott] #909293 10/13/08 02:56 AM
DEFBOY35 Offline
is the miata lsd a direct bolt in affair, or is there some sort of modifications required to make it fit? as well, what year etc was used, do you know?
who was it that did the swap successfully? perhaps they have some information to share.
Re: differential lockers [Re: DEFBOY35] #909294 10/13/08 03:58 AM
DennisThompson Offline
The late 80s early 90s Miata and non turbo RX7 should work but I have been unable to find even a used Torsen LS for under $900.00. The Torsen locks almost as positive as a true locker. If anyone finds a good sorce set us know.
Dennis
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6459 MB (Peak: 0.7674 MB) Data Comp: Off Server Time: 2026-10-24 13:11:12 UTC
