Page 3 of 3 1 2 3
Re: differential lockers [Re: DennisThompson] #909305 10/20/08 08:17 PM
logansportage Offline
When I called Eaton back in March they still had the parts, but yes the "Spring and Clutch Rebuild Kit" for the Sportage was no longer in production. I asked if they could check to see if the parts were used in any other "Kits" and let me know so I could order that rebuild kit instead of using the old Sportage P/N. I also asked for pricing and they said only "Distributors" can get pricing. I have not heard from them since and have left a couple of messages.
Re: differential lockers [Re: logansportage] #909306 02/03/09 05:46 AM
wd8cdh Offline
Dave,
How well did it work? Any info on that LSD would be great. Maybe I can find one locally that I can pull and drop into the front end.
Thanks.
I'm the one who put the Miata Torsen into the front of my Sportage back in '04. It works great but I don't even notice it. The truck just goes where I point it with no jerking, no clunking, and no fuss. Much better in the ice and snow and mud than a regular LSD. For 4wd, it was an even bigger improvement than when I changed the rear open diff. to an LSD.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: differential lockers [Re: wd8cdh] #909307 02/03/09 04:27 PM
Everet Offline
Thanks for the info on the Miata diff. I spent several hours searching the forum about this fit. I'm going with a 89 RX-7 non-turbo lsd in the front. Got it for $50. I read on some Miata forums that it is a direct swap. Not as good as your Torsen, but a lot cheaper.
Thanks for your input.
Everet
Re: differential lockers [Re: logansportage] #909308 02/08/09 02:32 AM
Sportage Offline
Everet,
The web site was www.trackfinder.co.kr.
While browsing I tried the above link and it is now working and there is an english section on the locking diffs. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Dare to be different
'01 Long body, 40mm lift, AVM manual hubs, snorkel.
Re: differential lockers [Re: logansportage] #909309 02/10/09 07:20 PM
BigLar Offline
I seem to remember several years ago that someone had installed a miata torsen type diff carrier on the rear of a 95 kia sportage (4wh dr of course). All that was necessary was to install my ring gear on the carrier and re-install and adjust.anyone remember this or can help me????
Re: differential lockers [Re: BigLar] #909310 02/11/09 12:23 AM
DamKia Offline
Kia Moderator
It was the front diff (7"). Try searching...
Re: differential lockers [Re: DamKia] #909311 02/11/09 07:40 AM
A
Adskia Offline
there is thread on this subject else where........ i am having some lock-right style lockers made for the front and rear diff of my sportage.........
THE POWER TO SUPRISE.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6261 MB (Peak: 0.7329 MB) Data Comp: Off Server Time: 2026-11-02 04:00:35 UTC
