Power steering bracket for 304 / HEI distributor interference #909342 10/09/08 03:20 PM
RCCMAN Offline OP
I have installed a HEI distributor on my amc 304, the power steering pump is all over it. Has anyone ran across this problem and if so what is the fix?
Thanks,
RCCMAN
Re: Power steering bracket for 304 / HEI distributor interference [Re: RCCMAN] #909343 10/11/08 01:04 AM
rixcj Offline
If you bought a longer power steering belt, it would allow you to pull the pump toward the drivers side more, providing clearance .
'79 CJ5,401,t-18/d20,dana30/amc20(Mosers),GM HEI, Edelbrock Performer intake,Holley 600, ps/pb, 'glass tub/1pc. tilt nose, 33x12.50x15 BFG T/A's. Lots more to be done...
Re: Power steering bracket for 304 / HEI distributor interference [Re: RCCMAN] #909344 10/11/08 10:37 PM
BobRowe Offline
I have a D.U.I HEI distributor on my AMC 360 and it doesn't interfere with the power steering pump. Try the previous suggestion of a longer belt
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5913 MB (Peak: 0.6437 MB) Data Comp: Off Server Time: 2026-06-10 01:41:36 UTC
