fuel injected to carburated
#909417
10/09/08 11:41 PM
hey guys.. my question for you guys is how hard is it to convert a fuel injected 22re motor to a carburated motor??? I might do this to my '93 pickup.. what is required to do this swap?
Re: fuel injected to carburated
[Re: Anthony_89]
#909418
10/10/08 01:26 AM
Why? <img src="/forums/images/graemlins/zombie.gif" alt="" />
Richard S. 88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds Proud to be an American. Blessed to be a Texan!
[Re: Anthony_89]
#909419
10/11/08 03:07 AM
I did it the other way around. 22R to 22RE Seemed like a big improvement to me. Also seemed simpler than messing around with all those hoses and vacuum valves that the carbed motor has. I hear you can strip down a 22r to make it pretty simple, but the factory set-up in my '84 22R w/California emissions was complex.
For your case though it comes down to wiring and fuel. You can leave the electric efi fuel pump in your tank and use a regulator to lower the fuel pressure or you can use the engine mounted mechanical fuel pump to pull fuel through the disabled electric (in-tank) fuel pump.
As far as the wiring goes I don't know if you can use the 22RE wiring and computer to run a 22RE distributor and ignitor in your 22R motor. Although it seems like the computer would freak out with out a throttle position sensor signal and a air flow signal. You probably would need to do a complete wiring harness swap. -- Matt
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
[Re: Richards19884x4]
#909420
10/11/08 02:04 PM
Why? <img src="/forums/images/graemlins/zombie.gif" alt="" /> Anthony - I'm also curious. Why would you want to do this. What's the reasoning behind your doing it?
canyon country explorer 1993 4x PUP
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6008 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-07-13 21:03:56 UTCValid HTML 5 and Valid CSS
