Page 1 of 3 1 2 3
Painting a hardtop.... help? #910575 10/13/08 06:08 AM
the_other_guy Offline OP
Since I painted my jeep a few weeks ago, I decided I should also paint my hard top for good looks.
I never would have guessed painting the top would have been harder than the vehicle itself.
1st off. I cleaned it, and sanded it, and tried some rustoleum flat black with my spray gun. turned out terrible... some parts glossed up and it just looked bad...
so i sanded it again, and tried spraycan duplicolor truckbed liner. almost 1/4 of the surface orange peeled really bad.
now im taking all of the paint off, and going to the plain white fiberglass to start over fresh. its about 75% off as of now.
any tips?
its starting to get cold, and a top would be nice about now...
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: Painting a hardtop.... help? [Re: the_other_guy] #910576 10/13/08 02:20 PM
DBL_DTY97TJ Offline
Get it down to the fiberglass then talk to someone who paints fiberglass boat hulls. Or did...Most of them are out of work around here.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Painting a hardtop.... help? [Re: DBL_DTY97TJ] #910577 10/13/08 03:40 PM
BigJim Offline
I suggest some of that 2-part epoxy garage floor paint. And paint it with a roller real quick. The stuff is self leveling and will finish itself in a high gloss. And it will stick to anything.
Re: Painting a hardtop.... help? [Re: BigJim] #910578 10/13/08 09:27 PM
Seattlegti Offline
Let us know what you end up using. I'd like to repaint the top of my Wrangler with something tougher.
The low branches are doing a number on the fiberglass.
Did you sand the texture down to a smooth finish?
Hoping I can avoid it, the ribs on the front panels would be a challenge sanding.
Re: Painting a hardtop.... help? [Re: Seattlegti] #910579 10/14/08 07:25 AM
Turns out, under the paint, the white fiberglass is smooth as, well, glass. the texture was in the paint.
I havnt finished removing all of the paint, but when i do, im going to sand it real good to rough it up a bit.
in response to BJ. I like everything about your idea except the high gloss part. i was hoping for more of a semi gloss, or even almost a flat finish.
but at this point, Im opened to all options.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Painting a hardtop.... help? [Re: the_other_guy] #910580 10/14/08 01:20 PM
BigJim Offline
That epoxy paint might come in different glosses.. I havn't checked. The granular stuff on there might be simple SAND. It is a easy matter to spread sand on a finish to get a rough finish.
One can PRACTICE spreading with a simple hand-held seed spreader for yards.
I wouldn't spend too much time SANDING as I'd like the top coat of the glass to remain intact.
Re: Painting a hardtop.... help? [Re: BigJim] #910581 10/14/08 07:39 PM
Seattlegti Offline
Good point, it's probobly like that orange peel stuff they spray interior walls with to cover apprentice grade sheetrock work. <img src="/forums/images/graemlins/ignore.gif" alt="" />
I was looking at my friends old Landrover Discovery and pondering what white above the raingutters would look like on a black top. Might have to do a little phototshop and see.
Re: Painting a hardtop.... help? [Re: Seattlegti] #910582 10/14/08 10:28 PM
you mean like a 2 tone? I am considering some sort of 2 tone, to match my freshly painted black and green jeep
Re: Painting a hardtop.... help? [Re: the_other_guy] #910583 10/14/08 10:31 PM
BigJim Offline
Only in California!
Re: Painting a hardtop.... help? [Re: BigJim] #910584 10/15/08 01:48 AM
Only in California!
you know you love it. haha. It definitely needs a lift tho. having an unconventional paint job looks weird on a basically stock vehicle. I bought it with a 2" body lift, but i dont consider that a lift, and I will probably take it out when i get a real lift.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6413 MB (Peak: 0.7659 MB) Data Comp: Off Server Time: 2026-05-29 19:53:48 UTC
