help with ID on this 87 toyota truck - check out pic !! #910746 10/14/08 04:42 AM
moto629 Offline OP
does anyone know if this is a custom made cab ? i've got a chance to buy this truck, its got 59,000 original miles on it-- i havent seen the truck in person yet and i've never seen anything like it , its an 87 4x4 22r carb - i've got several x-cab trucks 85-89 and this one still has a 6ft bed ? and the x-tra cab is as big as the front seats ! thanks in advance for any info !!
Re: help with ID on this 87 toyota truck - check out pic !! [Re: moto629] #910747 10/14/08 04:52 AM
kewlynx Offline
They were known as a king cab, IIRC. There used to be an '82 in the junkyard up here with a 20R in it. If you can get the VIN, see if it's loaded on Carfax for a summary.
**ubi apis- ibi salus**
Re: help with ID on this 87 toyota truck - check out pic !! [Re: moto629] #910748 10/14/08 08:45 AM
Snowtoy Offline
Here in CA they were called Custom Cab's, as with the Trailblazer and Trekker more than one company did the conversion.
Basically they just stretched the frame and added extra seating.
You really can't get that much appreciation for their length from the photo, but they are about 3' longer than the standard cab/bed.
It is going to take some work to restore, there looks to be radiator support/radiator/inner fender damage, likely bent frame right behind the drivers tire, I imagine the front of the engine may be damaged as well. It is all fixable, just wont be a quick fix.
Depending the price, and your plans it could be a nice to platform to rebuild.
Re: help with ID on this 87 toyota truck - check out pic !! [Re: Snowtoy] #910749 10/14/08 03:14 PM
stock87 Offline
There's actually an 85 that lives out in Grizzly Flat that is the coolest one I've ever seen. 85 (solid axle), absolutely mint, bright red, and it has a custom shell that matches the bumped section of the rear cab.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: help with ID on this 87 toyota truck - check out pic !! [Re: moto629] #910750 10/14/08 07:13 PM
moto629 Offline OP
thanks for the info, i'm still deciding on if i'm going to buy it, its $1500 and its crashed you can see, although it does have going for it a nice solid frame and 59,000 miles, i've fixed worse wrecks and i've got all the parts. thats cool they actually lengthend the frame to build it, I had never seen anything like it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6084 MB (Peak: 0.6731 MB) Data Comp: Off Server Time: 2026-05-29 15:01:02 UTC
