Headbolts #911218 10/16/08 05:14 PM
krb90 Offline OP
OK, so I got the 3.0 headbolt set from engnbldr....since these are not TTY bolts, do I follow the same torque procedure as outlined in the FSM, particularly the 3 step progressive torqueing? Or, is there a set torque I should apply in a cross pattern and that's it?
Re: Headbolts [Re: krb90] #911219 10/17/08 01:20 AM
OOP'S Offline
Why not e-mail or call EB for the correct answer?
engnbldr@engnbldr.com
(503) 257-7947 9am-4pm Pacific M-F
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Headbolts [Re: krb90] #911220 10/17/08 01:36 AM
engnbldr Offline
>>>*I think I already answered tbis one directly but just in case.... Use the same specs as stock, 33# in sequence, then 1/4 turn in sequence, then 1/4 turn again....*EB
*Beats the he** outa me!....*LOL**...
Re: Headbolts [Re: engnbldr] #911221 10/17/08 03:26 AM
kewlynx Offline
Seems to me there's a TSB out there for that torque sequence Ted.
For the poster, go to the library link in the FSM sticky in this section and look up your rig; should find the TSB there, IIRC. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
**ubi apis- ibi salus**
Re: Headbolts [Re: OOP'S] #911222 10/17/08 04:40 PM
krb90 Offline OP
I did already. Email must have gotten lost.
Everything is square now.
Thanks guys.
Re: Headbolts [Re: krb90] #911223 10/17/08 05:32 PM
krb90 Offline OP
Actually, since we're all here, I have another question. When I re-torque, I assume I use the same exact procedure? Or, if they are all still holding over 33#, do I still do (2) 1/4" turns?
Basically, I mean, if I don't have a final torque setting, how do I know they're tight enough and all tightened the same amount? With TTY bolts, they'll stretch so I can see why you could give it another go around and still keep uniformity.
Or, do I need to quit over-analyzing all this and just do what I'm told?
Re: Headbolts [Re: krb90] #911224 10/17/08 05:52 PM
engnbldr Offline
>>>*Follow the FSM exactly, same torque procedure. The only difference in this type of bolt compared to stock is they stretch the same way but don't stay stretched should you need to remove them.
Thus reusable several times should you need to. Actually Toyota says theirs are also reusable, but we tried that several times and had just one or two unhappy results so we started replacing them every time....*EB
Re: Headbolts [Re: engnbldr] #911225 10/17/08 06:15 PM
krb90 Offline OP
aaahhhhhh. ok, i get it now.
I better not ever have to re-use them.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6275 MB (Peak: 0.7274 MB) Data Comp: Off Server Time: 2026-05-29 19:00:22 UTC
