DISTRIBUTOR DISINTIGRATED!!!!!!! #911237 10/16/08 07:58 PM
RALFIRECAPT Offline OP
I was just driving along on my 77 CJ5 and it just cut off. No sputtering, no warning, just off. It would turn over fine and have a gas smell, but would not start. I looked under the hood and first thing I noticed was my distributor twisted way around. I pulled the cap off and found several pieces of white plastic, a small screw and a spring inside. I pulled the distributor(the lock bolt was still tight, but it had torqued enough that it broke the lock washer) and checked for damage to the gear. It looked normal. I guess something just broke inside and locked it up. Ever had that happen before???
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: RALFIRECAPT] #911238 10/16/08 09:23 PM
BigJim Offline
The gear has a drift pin that holds it in place. I would be taking the gear off and pulling that sucker apart just to see what HAD happened. Does the shaft still turn in the housing? There is little that CAN go wrong with the primitive way them things are put together. Just a shaft and sleeve bearings is all that is ni there.
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: BigJim] #911239 10/16/08 09:44 PM
I pulled the distributor out and the gear and pin appear OK. The shaft does turn freely now that I got all the broken parts out.
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: RALFIRECAPT] #911240 10/17/08 02:49 AM
BigJim Offline
Sounds like something came loose and got lodged between the rotating parts and the cap...don"t it?
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: BigJim] #911241 10/17/08 07:24 PM
I guess thats it. I've never seen that happen. I opened it up and found several pieces of stuff. I have a new HEI that I haven't gotten around to putting in yet. I guess its time now, Huh!!!
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: RALFIRECAPT] #911242 10/17/08 08:44 PM
DBL_DTY97TJ Offline
Hey Capt., What part of NC are you in?
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: DBL_DTY97TJ] #911243 10/17/08 09:52 PM
BigJim Offline
Wilmington is just north of South Carolina near Carolina Beach... And just north of Myrtle Beach South Carolina.. I once knew the area well.
I wonder if Joyce Wright is still alive..
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: DBL_DTY97TJ] #911244 10/18/08 02:29 PM
I'm in Knightdale, Just east of Raleigh. I make it to Wilmington on occaision.
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: BigJim] #911245 10/21/08 05:22 PM
DBL_DTY97TJ Offline
That wouldn't be the Joyce Wright who is the wife of former Democratic House member Thomas Wright would it?
Re: DISTRIBUTOR DISINTIGRATED!!!!!!! [Re: RALFIRECAPT] #911246 10/21/08 05:27 PM
DBL_DTY97TJ Offline
Got any good wheelin' places over there? There's not much around here, and what there was is being closed for environmental reasons or developed. Uwharrie is a load of fun, but a heck of a hike just to get there.
PHP: 7.4.33 Page Time: 6.233s Queries: 16 (0.005s) Memory: 0.6352 MB (Peak: 0.7418 MB) Data Comp: Off Server Time: 2026-06-19 09:27:15 UTC
