Getting a 0401 code on your second generation Isuzu V6? Here is what you need:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95947
Remove the hex plug from below the EGR and use one of these brass brushes to remove the carbon. Push it in a half inch and pull it out. Repeat, going a little deeper each time until you bottom out the brush at the center of the intake manifold. You will be amazed at the amount of carbon that comes out!
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
