BATTERY RECOMENDATION ?? #911550 10/18/08 11:03 PM
KB2IAW Offline OP
O.K. so now i have the brake situation under control And im looking for recomendations for a new battery replacement , I was thinking deep cycle marine type ANY PROS CONS ??? <img src="/forums/images/graemlins/confused.gif" alt="" />
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: BATTERY RECOMENDATION ?? [Re: KB2IAW] #911551 10/18/08 11:40 PM
grass13 Offline
why pay that kind of jack for a battery when you can go to checker and get a 72 month with a progressive warrenty for about $75. here in ut we have all the high and low extremes, ive only a a couple of cold cranking issues and each time ive just gone in and used that progressive warrenty. if youve got a good charging system, imho, a big old fancysmanchy battery is overrated.
Re: BATTERY RECOMENDATION ?? [Re: grass13] #911552 10/19/08 02:13 AM
FatTony Offline
If you do a lot of offroading I'd suggest an optima. They come in starting or deep cycle, they're leak proof, vibration and shock resistant, and they last way longer than a normal battery. A warranty is great, but when your battery dies 20 miles into the bush it doesn't mean crap.
88 Raider sas, doubler, boggers
Re: BATTERY RECOMENDATION ?? [Re: FatTony] #911553 10/19/08 03:19 AM
PHIL_ Offline
Just came home from buying two yellow tops (my truck has duals, oe). They are smaller than the oe ones. Do some reading online - AGM batteries have a lot of advantages over wet cells. But it depends on how you want to use it.
Re: [Re: PHIL_] #911554 10/19/08 05:18 AM
I've had one Optima red top for 11 years almost, it's been in numerous trucks that I've had during that time, now powers our '05 GMC crew after the Delco 84-month went 32, sucker.
I've heard from a few parts guys that quality issues exist with the red tops due to excess demand by the US military...opinion or fact I can't confirm. There are numerous posts elsewhere about the Yellow tops, Pirate for example. <img src="/forums/images/graemlins/smile.gif" alt="" />
I'm sold on my old Optima and will be buying some more, gotta' support my Fleet.
Re: BATTERY RECOMENDATION ?? [Re: FatTony] #911555 10/19/08 02:41 PM
Angelo Offline
I have a yellow top for the past 4 yrs now, no problems and have extensive wiring to it too (correctly done I might add, for those worried)
x2 You'll spend 3 times more on a battery if you have to get a tow truck out to get ya. <img src="/forums/images/graemlins/drunk.gif" alt="" />
Wish I had duals <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: BATTERY RECOMENDATION ?? [Re: Angelo] #911556 10/20/08 12:21 AM
93montero_sr Offline
Optimas are good unless you run them dead they dont recharge very well. Autolite batterys from kragen or checkers dont last very long for me im on my 3rd one in the last 1 1/2. I like the duralst gold and interstate batterys.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: BATTERY RECOMENDATION ?? [Re: 93montero_sr] #911557 10/20/08 12:54 AM
FatTony Offline
Optimas don't like to charge fast when you kill them. Leave it on trickle overnight and you're good to go though.
Re: BATTERY RECOMENDATION ?? [Re: FatTony] #911558 10/20/08 02:30 AM
ghostraider Offline
So True.
Only bad point i know of about the Optima i have in my Truck:
It seems to discharge quickly if the alarm is armed!
Solved that by Starting it up every week without fail
<img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: BATTERY RECOMENDATION ?? [Re: ghostraider] #911559 10/21/08 01:34 AM
Ditto on the autozombie Duralast Gold. 5yr non-prorated warranty. Walked in with a 4.5yr old Gold from then daughter's 91lwb, and walked out with all my money still in my pocket and a brand new Gold. I used the unspent jack to buy a jump box with air compressor.
AND, I carry 4' of romex and an 18v DeWalt battery...
PHP: 7.4.33 Page Time: 4.822s Queries: 16 (0.005s) Memory: 0.6433 MB (Peak: 0.7679 MB) Data Comp: Off Server Time: 2026-10-22 12:12:39 UTC
