CB mounting #911598 10/19/08 05:09 AM
RatLabGuy Offline OP
Wondering if anybody has a nice clever spot/setup for mounting a CB unit in the cab. I just got a cheapy $40 box, standard size w/ cord mic etc.
I was looking at the bracket that holds the rearview mirror in, considering making a plate and bracket to come off of those holes... but that dosn't look real substantial for holding alot of weight.
Question Reality.
Re: CB mounting [Re: RatLabGuy] #911599 10/19/08 02:00 PM
Billydkid Offline
My last 2 trucks (a 93 runner and 92 truck) I removed the ashtray and bracket and mounted my cb's there. It was out of the way and fit nicely. It has to be a smaller radio to fit though. Last one was a cheaper $40 radio from Wal-Mart. I did have to make up my own bracket however, because the one that comes with the radio wouldn't fit with the big knobs on the sides.................
93 4runner V6, 4.88's, 31" mt's with more to come.
03 Tundra V8 on 265's
Re: CB mounting [Re: Billydkid] #911600 10/19/08 03:51 PM
OOP'S Offline
Here is how I mounted mine when I first got my truck. It is a piece of .120 aluminum plate that I bent to the contour of the roof and it is mounted with the same screws as the mirror. I glued some gray carpet on it to match the headliner. I also spaced the CB mount down with a piece of finished Oak that is 1 x 1. Worked great and was very solid.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: CB mounting [Re: OOP'S] #911601 10/19/08 09:09 PM
Thanks David, that's just about what I was thinking.
Now I'm windering... as long as I'm taking that mirror off, is there an upgraded version, or a cool way to add map lights, or even a nice aftermarket bolt-on unit w/ built in accesories (like lights) that might replace it?
Question Reality.
Re: CB mounting [Re: RatLabGuy] #911602 10/19/08 09:31 PM
P
philly Offline
the tacoma rear veiws are nice.
heres mine.
Re: CB mounting [Re: philly] #911603 10/20/08 02:30 AM
ScaldedDog Offline
I used to have my CB mounted like this:
As I got older, though, I couldn't lean back far enough to read the display. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Also, the mic and cord seemed like they were always in the way. Also, I like having the sunroof off whenever possible, and this setup precluded that.
I ended up putting this radio (a Cobra 25) in my two rig, and took the tow rig's Uniden 520 and mounting it in the dash where the switches are in this photo (just above the CD player). I attached the mic mount to the side of the plastic hump cover, right in front of the driver's seat. I love this setup.
Mark
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
http://www.scaldeddog.com
Re: CB mounting [Re: RatLabGuy] #911604 10/21/08 01:59 AM
Snowtoy Offline
I have mine mounted to the glove box.
I used a 2"x6"x1/8" piece of aluminum inside the glove box as backing to reinforce the mounting surface. Over the last 18yrs I have had two mounted there, and there has been no warping of the glove box from the extra weight.
The 3rd gens have more leg room, but I have mounted CB's the same way in both 1st and 2nd gens, and you only loose leg room w/the large CB units.
In my other truck the antenna was a little short(to cheap to buy a new one), so I mounted it to the tranny tunnel. It is out of harms way, but I plan to go with a better unit, i.e., one w/greater range/functions, when I do it will be mounted to the glove box as well.
Re: CB mounting [Re: Snowtoy] #911605 10/21/08 03:09 AM
4Crawler Offline
I used to run mine on the driver's side door panel:
Re: CB mounting [Re: RatLabGuy] #911606 10/22/08 10:24 PM
JD9996 Offline
I like it here [img][image]http://i171.photobucket.com/albums/u288/jd9996/DSC02998.jpg[/img][/image]
Re: CB mounting [Re: RatLabGuy] #911607 10/30/08 09:20 PM
TRDSR5 Offline
It's not the full size radio but....
[img][image]http://i38.photobucket.com/albums/e136/trdsr5/SR5console.jpg[/img][/image]
used bracket that came with CB, just upside down and screwed it to side of shift console. Had to remove little cubby pocket that sat below ashtray.
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6412 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-10-21 16:19:23 UTC
