258 burnt valve #911788 10/20/08 08:47 PM
jstritec Offline OP
My jeep is acting like it's got a burned valve. It runs really rough at idle (missing). I have not pulled the plugs or done a compression check yet but I do have a spare 258 that was rebuilt about 30K ago I was working on (its dissasembled now). If that is the problem, would I be able to stick that head on, with new lifters and pushrods, without any machine work or would that be a bad idea?
80 CJ-7.
It runs
Re: 258 burnt valve [Re: jstritec] #911789 10/21/08 04:02 AM
BigJim Offline
Sure that'll work finr.. I betcha 99% of all head millings are useless. A slightly warped head was warped when it was ON THE ENGINE! It gave no problems then and when reinstalled it will torque down tight again.
Re: 258 burnt valve [Re: BigJim] #911790 10/21/08 03:51 PM
jstritec Offline OP
Thanks Jim
I'm thinking if I pull the head I might as well look into a 4L head swap.
Josh
80 CJ-7.
It runs
Re: 258 burnt valve [Re: jstritec] #911791 10/21/08 04:09 PM
BigJim Offline
That swap can getcha into a lot of time and trouble.. I think I would pull the offending head and lap a new valve in place (leaving everything else alone) and reinstall it! Then If I wanted an engine with the 4.0 head I'd be building one in my shop to install the complete engine in the future.
Re: 258 burnt valve [Re: BigJim] #911792 10/21/08 06:46 PM
jstritec Offline OP
Jim
You're probably right. I mean if it comes down to really upgrading a 258 the best bet would be to just find a pulled 4.0 and stick that in.
Josh
80 CJ-7.
It runs
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6054 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-05-30 01:17:58 UTC
