it just quit #911861 10/21/08 11:49 AM
drtydzl Offline OP
the 89 just quit it will not start i think the injection pump died it turns over and no fire it ran really rough the last two days it ran and then it just died has fuel in the tank not sure how to check to see if its pumping to the injectors the fuel lines are good and so is the filter it doesn't seem to be loading up the cylinders ether is there a fuse or something im missing or anything else to check for thanks in advance for the help
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED
1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW
CURRENTLY LOCATED IN JAPAN
Re: it just quit [Re: drtydzl] #911862 10/21/08 08:20 PM
bae146 Offline
You can check the fuel cut out solenoid and see if it is working.
Re: it just quit [Re: bae146] #911863 10/22/08 01:59 AM
drtydzl Offline OP
do you have any info on where it is and what it looks like thanks for anything you can provide me with
Re: it just quit [Re: drtydzl] #911864 10/22/08 03:28 AM
bae146 Offline
If I remember right it is the blue wire going to the rear of the injector pump.
Re: it just quit [Re: bae146] #911865 10/22/08 08:13 AM
drtydzl Offline OP
wow im not the smartest but sometimes there are vacume lines and they need to be hooked up shes back up and running thanks for the blue wire comment the line is just above that wire and it was unplugged now its running good again..
Re: it just quit [Re: drtydzl] #911866 10/22/08 02:11 PM
bae146 Offline
Glad it is up and running again..
Re: it just quit [Re: bae146] #911867 10/22/08 02:33 PM
PHIL_ Offline
Re: it just quit [Re: PHIL_] #911868 10/25/08 08:05 AM
drtydzl Offline OP
well the pump went south today just started pukeing diesel all over its time to retire this one to anyone know anything about the 6g74 3500 v6 gasser
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6222 MB (Peak: 0.7036 MB) Data Comp: Off Server Time: 2026-11-18 11:51:39 UTC
