it just quit
#911861
10/21/08 11:49 AM
the 89 just quit it will not start i think the injection pump died it turns over and no fire it ran really rough the last two days it ran and then it just died has fuel in the tank not sure how to check to see if its pumping to the injectors the fuel lines are good and so is the filter it doesn't seem to be loading up the cylinders ether is there a fuse or something im missing or anything else to check for thanks in advance for the help
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED 1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW CURRENTLY LOCATED IN JAPAN
Re: it just quit
[Re: drtydzl]
#911862
10/21/08 08:20 PM
You can check the fuel cut out solenoid and see if it is working.
Re: it just quit
[Re: bae146]
#911863
10/22/08 01:59 AM
do you have any info on where it is and what it looks like thanks for anything you can provide me with
Re: it just quit
[Re: drtydzl]
#911864
10/22/08 03:28 AM
If I remember right it is the blue wire going to the rear of the injector pump.
Re: it just quit
[Re: bae146]
#911865
10/22/08 08:13 AM
wow im not the smartest but sometimes there are vacume lines and they need to be hooked up shes back up and running thanks for the blue wire comment the line is just above that wire and it was unplugged now its running good again..
Re: it just quit
[Re: drtydzl]
#911866
10/22/08 02:11 PM
Glad it is up and running again..
Re: it just quit
[Re: bae146]
#911867
10/22/08 02:33 PM
Re: it just quit
[Re: PHIL_]
#911868
10/25/08 08:05 AM
well the pump went south today just started pukeing diesel all over its time to retire this one to anyone know anything about the 6g74 3500 v6 gasser
