Page 1 of 3 1 2 3
96 grand keeps dying #912337 10/23/08 10:04 PM
MrCrowley Offline OP
my wife and i jboth have jeeps i have a 93 grand cherokee limited with the 5.2v8 and she has a 96 grand cherokke laredo its the 4.0 she is just 2 wheel drive. But my question is this it doesnt do it all the time and it does it whenever it wants to. she can start it up and it run fine and put it into gear and as soon as w=she starts to move it will die or sometimes while driving down the road or just sittin at idle one day it took me almost 45 min to get out of wal mart parking lot cause every few feet i drove it woulod die. i have changed the cap and rotor and coil wire cause the coil wire looked all nasty so when i popped the cap to check the rotor they were too so they both got changed too. we both know a pretty good amount about cars but we cant figure it out. can anyone help me? cause i really dont want so 5 and dime myself to death to fond out what is wrong with this damn thing.
thaks in advance for any advice
Marty
Re: 96 grand keeps dying [Re: MrCrowley] #912338 10/23/08 10:23 PM
BigJim Offline
If it dies at high speed also, I would be looking into a fuel filter.
If only at low speeds I'd be cleaning the IAC..
Could be a number of other things but I'd be starting there.
Re: 96 grand keeps dying [Re: BigJim] #912339 10/24/08 08:33 PM
its been doing it at all speeds. somtimes at idle sometimes at highway speeds sometimes right after you atart it and it doesnt do it all the time it has went sometimes a week or 2 before doing it again. im going to try the fuel filter this monday when i get paid. and what was the other thing? i have never heard of one of those before. and on my jeep the 93 grand limited how hard is it going to be to chang a front axle shaft? i broke the cv joint on te driver side and i have never changed an axle before.
thanks for all the help i appriciate it greatly
Marty
Re: 96 grand keeps dying [Re: MrCrowley] #912340 10/25/08 02:24 PM
fred1980 Offline
Are you getting the "Check Engine" light? Have you run the trouble codes? There's a lot of things (sensors mostly on these jeeps) that it could be but my best guess is that it might be your CPS (Crank Position Sensor). Mine went south once and my Jeep would not stay on without me keeping my foot on the gas all the time... swapped it out and no more problems. But again, BEFORE you spend money on the sensor or anything else run your trouble codes... On Jeep ZJ's just cycle the ignition key On/Off/On/Off/On within 5 seconds (you don't turn on the jeep) then the codes will flash where your odometer is located... it will start with "12" and end with "55"... any other numbers flashed inbetween will be your trouble codes. Hope this helps.
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
Re: 96 grand keeps dying [Re: MrCrowley] #912341 10/25/08 02:41 PM
fred1980 Offline
Marty
Forgot to answer your other questions... replacing the fuel filter on ZJ's is a pain in the behind to put it lightly, you have to drop the gas tank as it's located IN the fuel pump that is located guess where... in the gas tank. The fuel pump is non-servicable meaning that you have to buy a NEW fuel pump to replace the filter ($200-300 depending on where you purchase it) so check your trouble codes before you go out and purchase a fuel pump.
Front axle shaft removal on a D30 is fairly straight forward can be done in 15-30 mins depending on rust or other variables but if it's your first time doing something like this then give yourself about an hour or so. Word of advice, spray all the nuts and bolts you will be removing with WD40 at least a day in advance to loosen everything up, you WILL need a 12-point 13MM socket to remove the 3 hub bolts from the knuckle (nothing else will work and you risk stripping the bolts if you try it with anything else) and a 32MM or 36MM socket (can't remember the exact size off the top of my head) to remove the stub-shaft nut. Having a breaker bar will make this a whole lot easier of a project but it's not necessary.
Fred R.
Re: 96 grand keeps dying [Re: fred1980] #912342 10/25/08 02:59 PM
Brown81CJ5 Offline
ALL wranglers from 87-06 use 36mm socket.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 96 grand keeps dying [Re: Brown81CJ5] #912343 10/29/08 06:00 PM
thank you for all the help guys i reall appriciate it and bj i found out what the iac is its right there in the throttle body i sprayed the trottle body out rally good with some carb cleaner and it seemed to help alot but not fix the problem i talked to a local mechanic i know and he said i need to clean the iac with mass air flow sensor cleaner cause everything else is to corrosive so i will do that today when she gets back for class. now on to the fuel filter it does have one in the tank but its only the sock filter that is on the bottom of the fuel pump. it also has an external filter that is located on the body pretty much right over the rear axle right? cause it has some sort of filter there and it looks exactly like a fuel filter if you ask me. and on changing my axle shaft would it be beter to buy new or used? i know that probably sounds like a dumb question but i know a guy that runs a small used car dealership and is in really good with a good junkyard and he can get parts pretty cheap and i didnt know if it would be a bad idea or not to just see of he can get me a used one from them or not. cause a new one isnt to expensive auto zone has one for around a hundred bucks but with me being the only one workin for now and we have 3 kids the cheaper the better. so any advice will help
thanks so much for all the help guys
Marty
Re: 96 grand keeps dying [Re: MrCrowley] #912344 10/29/08 09:38 PM
BigJim Offline
Heck I'd go for a used one in a heartbeat.. THE RIDE WON'T KNOW IT AIN'T NEW! Very little to wear on an axle.. The JR wouldn't send your friend a bad one for sure.
Re: 96 grand keeps dying [Re: Brown81CJ5] #912345 10/30/08 05:41 AM
ok i ran the trouble codes all i got was a 12 and a 55 the check engine light isnt on so i went to the dealer and all they can tell me is to come in and have a diagnostic ran. but that was nothing new they just want your money. so im lost i have done everything but jack up the radiator cap and replace everything underneath it. the only thing i havent done yet is replace what looks like the fuel filer on the body under the damn thing. its starting to make me pretty mad cause i know im not stupid cause i do all my own work cause i cant really afford to pay someone else. would a burnt plug make it do the same thing cause i was checking the tranny fluid today like i do once a week and im under the hood and it dies just like i turned the key off. no spitting or anything just stopped running. so i dont know what to do here
but if you guys can think of anything else it would be greatly appriciated
thanks again
Marty
Re: 96 grand keeps dying [Re: MrCrowley] #912346 10/30/08 02:31 PM
BigJim Offline
Ok so you have two of them... Go out there in the yard and swap the coils on the two vehicles.. That'll tell you if it is the coil... and they sometimes give similiar problems..
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6431 MB (Peak: 0.7710 MB) Data Comp: Off Server Time: 2026-05-29 18:59:53 UTC
