93 delica auto trans in dodge raider?
#912649
10/25/08 07:13 PM
I have found auto trans from a 93 Mitsu delica diesel van and thinking about swapping it in into my 87 raider 2.6l gas. It looks like it will bolt up but I have a few questions. Will the torque converter and shift points be ok behind the gas engine? Does this trans need a computer to function properly? Is this trans easily adapted to np 231 or dana 300 transfer case? The reason for this swap is to get lower t case gearing and right side t case output as I am swapping in Toyota solid axles front and rear.Thanks for any information y'all can provide. ED
87 raider,soon to have toy axles,TBI 318,R150 5spd,dana 300!. 78 ramcharger 5.9 cummins powered, 67 coronet 500 383/727
Re: 93 delica auto trans in dodge raider?
[Re: coalburner78]
#912650
10/25/08 08:03 PM
Have you been on Outerlimits4x4? there are a few posts about delica transmissions on there recently. As far as i know the transmissions are the same but the ratios are different, And the delica has the factory SYE. Lordtrunks knows a lot more about these things maybe he'll post up.
[Re: TOASTY]
#912651
10/26/08 02:48 AM
I have compared the ratios but the diesel should have a bit lower ratio if not the same it won't be highier so i wouldn't worry about. If your swapping in a new transfer case i'd like to buy the delica transfer case if its the none rear slip yoke case.
89 2 dr turbo diesel 89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5972 MB (Peak: 0.6509 MB) Data Comp: Off Server Time: 2026-05-29 15:01:28 UTCValid HTML 5 and Valid CSS
