Compass/Temp Gauge #912832 10/27/08 03:29 PM
G
Guntero Offline OP
The light has seemed to have blown that illuminates my compass/temp gauge. I thought it was an issue of simply changing a bulb. So, I pulled the entire console apart and learned that whatever illuminates the compass/temp gauge is physically inside of the gauge itself as opposed to a bulb.
Has anyone had this issue?
And how do I get the gauge illumnitated again? New gauge or is there a way to replace whatever has blown?
Thanks
Guntero (died in battle)
1995 Montero LS - Matte Black
265/75R16 BFG All-Terrains
Guntero (current)
2001 Montero Limited - Gold
OME HD Lift
285/75R16 BFG All-Terrains
Re: Compass/Temp Gauge [Re: Guntero] #912833 10/27/08 06:39 PM
Scottie2113 Offline
there are two little tiny bulbs inside the compass, you have to use a small flat tip screw driver to get them out, you can order there from dealer for cheap if you get a smart parts guy that knows how to find just the right bulb. it fits into a plastic socket that you unscrew a quarter turn to get them out. covered with a blue plastic jacket. I have the part number at home, but I am in Iraq at the moment.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Compass/Temp Gauge [Re: Guntero] #912834 10/27/08 06:51 PM
sewerrat Offline
You can replace the bulb. A bit of work for a single bulb. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Remove the cluster, remove the clear face, pull the C/T gage. The bulb is in the back of the gage. Small, thin needle nose will reach in the hole. It's an odd bulb in an odd base. Dealer only part?
I found a replacement at a Pick & Pull, Some s**t heads smashed the clusters, made pulling the bulb easy.
95 Montero SR 3.5 sitting on the sidelines.
96 Montero LS Daily driver.
88 Audi 90 Quattro marking it's territory.
69 Bronco built but uncut garage queen.
TANSTAAFL
Re: Compass/Temp Gauge [Re: sewerrat] #912835 10/27/08 07:56 PM
Scottie2113 Offline
I am pretty sure there were two small bulbs in the compass, one will light it up enough, but there are two. it is a bit of work to take it all apart and you have to be careful, but if you take your time it isn't too bad. that is why I would do both bulbs, at least on my 97 and my dad's 99 there were two bulbs in the compass, one on each top corner.
Re: Compass/Temp Gauge [Re: Scottie2113] #912836 10/28/08 01:26 AM
sewerrat Offline
I have run across three different types of compass/temp gages. Mine had one that backlights the LCD. Accessed from a hole in the white plastic housing. Could have another on the circut board, I didn't look. <img src="/forums/images/graemlins/lol.gif" alt="" />
I just know the engineers would not completely hide a light bulb that deep. <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
I now have full lighting on the gage. There is a more standard type bulb in a normal holder for the oil pressure/voltage meters.
TANSTAAFL
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6096 MB (Peak: 0.6747 MB) Data Comp: Off Server Time: 2026-06-10 07:27:31 UTC
